Old 11-02-2020, 12:02 PM   #1
psavello
Default Follow-up to wheels/races question...
What is purpose of the inner/outer races of wheel hubs/bearings? Stability? If wheel hub fits snugly on inner/outer bearings and there is no play, what is function of races?
psavello is offline   Reply With Quote
Old 11-02-2020, 12:09 PM   #2
psavello
Default Re: Follow-up to wheels/races question...
No reply needed. Got it figured out!
Old 11-02-2020, 12:13 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I am assuming this question is directed to the front hubs, -and not the rear hub bearings.
The bearing races are there to support the roller portion of the bearing. The tapered design allows for a preload on the roller to be established which provides a stronger lateral support. The reason a race is used instead of the hub itself is because the race can be heat treated to provide a better wear surface for the roller. If the hub were to be used as the race, then the costs associated with heat treating the roller area would be much greater in production costs, and subsequent repair costs as the components wear.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-02-2020, 12:15 PM   #4
BRENT in 10-uh-C
Too late. Already typing the response when you figured it out, -and Ryan does not allow for us to delete our posts.
BRENT in 10-uh-C
