Old 01-10-2018, 01:03 PM   #1
1930artdeco
1930artdeco's Avatar
Default quick 3X plug question
Hi All,
I just installed, but can uninstall if need be, some new 3x plugs. The washer that came with them is concaved. I installed them so the washer would flatten out when tightened. Is this correct?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-10-2018, 01:31 PM   #2
1930-Pickup
Default Re: quick 3X plug question
The gasket will take the shape of the head/plug interface, which in this case should be flat. You should be fine, but retorque them after a few miles just to be sure.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 01-10-2018, 02:56 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Rule of thumb" for plug torque is 25 Ft Lbs.
Bills' Specs
"THE ASSISTANT GURU OF STUFF"
Old 01-11-2018, 10:31 AM   #4
burner31
burner31's Avatar
So...
1: Concave up, flat down
or
2. Concave down, flat up
Feedback?
Keith
Shawnee OK
'31 SW 160-B
Old 01-12-2018, 10:34 AM   #5
katy
katy's Avatar
Originally Posted by 1930artdeco View Post
Hi All,
Mike
Either way should be OK.
Old 01-13-2018, 10:00 AM   #6
burner31
burner31's Avatar
Answer to post #4 is:
Keith
Shawnee OK
'31 SW 160-B
Old 01-14-2018, 07:37 AM   #7
BILL WILLIAMSON
UNIFORM Torueing is MOST important, since plug HEAT is dissipated through the threads & gasket contact area. Make sure the head surface doesn't have paint build up.
Bill W.
