08-23-2016, 06:50 AM | #1 |
ammeter wiring 1937 ford
I am re-wiring a 1937 ford 1-1/2 ton with a cast iron head 85 horse flathead. System remains 6 volt positive ground. My question is pertaining to the wire from the generator back to the battery. Does this connection have to be after the ammeter in order to register charge on the dash or can it go straight to the battery?
08-23-2016, 08:13 AM | #2 |
Re: ammeter wiring 1937 ford
The stud on the battery side of the fuse is where the generator connection should be made. It is the connection point for both the generator and the battery power (and any other non-fused circuits). The ammeter goes between this stud and the battery connection. Last edited by JSeery; 08-23-2016 at 08:33 AM. |
