07-05-2016, 08:34 AM | #1 |
Holley 94 model 59
I am using this carb on a stock 1937 flathead 85 horse. Rebuilt the carb and replaced all gaskets, power value (7.5), new holley jets. (.51), and accelerator pump. The carb performs well but leaks into the intake when the engine is shut off...fills the intake above the throttle butterfly and leaks out of the throttle shaft. I suspect power valve is leaking. Other thoughts would be appreciated.
07-05-2016, 12:06 PM | #2 |
Re: Holley 94 model 59
Power valve mating surface is different on new valves. You must machine the surface flat to match the carb. Insure that the gasket is sealing by filling the bowl with fuel and setting the carb on a paper towel/table overnight.
Couple other points... Accelerator pump should be leather. The new blue ones are crap. And because the 94 is not stock on the '37, you'll need to block the third hole on your manifold to protect your power valve. This is usually done with the correct gasket.
Alan |
07-05-2016, 12:22 PM | #3 |
A leaky power valve gasket will not show up as leakage in the throttle bores. Float might be too high. When the engine is shut off, heat from the engine will heat the fuel causing it to expand and leak out the nozzles.
07-05-2016, 08:36 PM | #4 |
Thank you for the input. The carb is later than the engine and is properly fitted; however, the float height is definitely going to be something I check another time.
07-05-2016, 08:58 PM | #5 |
