Go Back   The Ford Barn > The Archives > Model-A
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Ignition cable question
What is the proper length of the ignition cable for a 28-29 without the ends. I have a decent looking cable that is missing the switch end and I want to make sure it is the right length before I go in search of a switch end to put on it. All I have to compare it to is an AR banana cable. Thanks Rod
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: Ignition cable question
About 26-1/2" give or take without ends on it, just the cable. When put together with both ends on the cable it is 28-29/32" to 29-5/32" from the center line of the wire connection on the switch end to the end of the threads on the distributor end, this is 29-29 cable. 30-31 is longer by about 3" give or take.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Thanks Looks like I can use this cable as soon as I can find a switch end in the parts barn. Rod
