03-06-2013, 07:00 AM | #1 |
Merc-o-matic linkage
I'm swapping my 6 and 3speed in my 54 custom line for a 312 and merc-o-matic out of a 57 mercury. The problem is, I don't know how the linkage should look like at all, the merc was push-button operated. On the transmission it is two arms on the same axle, and a hole with something that looks like a cable connection. Do I have to install a push-button panel to operate it, or is it some way to connect it to the three on the tree?
03-06-2013, 11:11 AM | #2 |
Re: Merc-o-matic linkage
One of the two arms is the gear selector. The other is the throttle control arm (passing gear). The hole? Speedometer cable?
03-06-2013, 11:50 AM | #3 |
No, it is not the speedometer cable, this one (it is actually 2) is just above the 2 arms, and has an inspection hole or something under, where I can see a rod with tracks on. I tried to move the rod up and down, and it clicks, just like a shifter arm... None of the arms clicks when I move it...
03-09-2013, 09:11 AM | #4 |
Here is how it looks http://i1323.photobucket.com/albums/...psbaf9555e.jpg
The cable hoes in where the screwdriver is placed! |
03-10-2013, 02:52 PM | #5 |
http://s1323.beta.photobucket.com/us...88236537018069 The cable goes in where the screwdriver is...
03-11-2013, 02:10 PM | #6 |
Sounds more difficult than it is. I couldn't open the picture; something about it is no longer up. If the hole you refer to is on a boss and does not enter the transmisson cavity, it's probably just a securing point ofr the speedometer cable as Y-Block said. Good luck, Motorhead |
03-12-2013, 12:42 AM | #7 |
03-12-2013, 12:44 AM | #8 |
