03-16-2022, 02:12 PM | #1 |
Horn button/light switch
Hello to all. I have a 1934 Fordor Deluxe and I'm till having issue with the headlights flickering and or turning off when brake is applied. They stop flickering and or come back on when you let off the brake. The brake pedal is not touching or rubbing anything but working the brake switch like it should. Also changed out brake light switch and no luck. Even wired around brake light switch and no luck.
Changed "all" of the bulbs and sockets and no luck. Only thing left I can think of is the horn button/light switch rod. Could this cause the problem. If so can you remove without getting a chop saw and cutting the top half of the car off LOL... Thank you for any help of advise. |
03-16-2022, 09:22 PM | #2 |
Re: Horn button/light switch
The horn button just grounds the horn via the rod contact with steering shaft. Only two things are hot all the time, horn, and brake light switch. When the headlights act up is the brake light still working? No answer here, just some food for thought. A friend recently had intermittent light problems and found the C clip had fallen off and was shorting in the light switch. good luck
03-16-2022, 09:44 PM | #3 |
Thanks for your reply. The brake lights work fine all the time. Just the headlights are a problem when brake is applied. Where is the C clip located? I’ve also had an issue with my lights being turned off when I turn the steering wheel to the right. The steering wheel moves the light switch to the off position. Would the C clip cause that. Do you know how to remove horn/light rod?
03-16-2022, 10:15 PM | #4 |
