Old 01-26-2018, 05:59 PM   #1
melisahe
melisahe's Avatar
Default 38 clutch petal problem
Put an 8rt in my 38 coupe. Now I can't get the clutch petal to clear the frame for the clutch petal to go to the floor. Can the petal arm be bent? The car has been converted to hydraulic brakes. What's the best way to solve this problem? All help deeply appreciated. Mike
melisahe is offline   Reply With Quote
Old 01-26-2018, 06:57 PM   #2
40cpe
40cpe's Avatar
Default Re: 38 clutch petal problem
I don't know why the engine affects the clutch pedal, but I put a '40 pedal assembly in my '38 and had to heat the clutch pedal and bend it to the left so it would pass to the left of the X-member.
Old 01-26-2018, 09:03 PM   #3
George/Maine
George/Maine's Avatar
If you have the same clutch pedal and trans you need the floor in the setup clutch play. What I think is the clutch pressure plate fingers are not the same and may need to make lever longer. or shorter. If the throw-out bearing has to go farther you need to make longer rod. I put 8rt in 47 coupe and had that problem.
George/Maine is offline   Reply With Quote
