04-30-2015, 08:25 PM | #41 |
Re: Manifold heater is ugly
So you think YOUR heater is ugly! This one is going away when I replace the exhaust manifold with a new porcelain coated one.
05-01-2015, 10:56 AM | #42 |
Re: Manifold header is ugly
I have an otwell with the bolts for the intake broken off and need to drill them out. I need to know if the holes go all the way thru.
05-01-2015, 11:07 AM | #43 |
I put the Snyders hot water heater in my A's. Not original but sure does a great job on the cold and snowy days. Wayne
05-01-2015, 02:08 PM | #44 |
I don't believe they do gridleak. I can check tonight for you.
05-01-2015, 04:59 PM | #45 |
I had my AutoLite "drop on" cast iron heater powder coated cast iron dark gray and it looks OK under the hood. I also keep it in place with a large hose clamp and remove it when not needed. In my closed cab pickup it gets very toasty warm on the coldest days.
05-02-2015, 01:46 AM | #46 |
05-03-2015, 11:39 AM | #47 |
Gridleak, I checked and one of my holes is 1/4 in in depth and the right hole is 1/2 in depth. Sorry I took longer than I said.
