08-04-2012, 01:21 PM | #1 |
noisy engine
Hi All,
What is a good additive to calm a noisy engine that runs great but has a little noise to it. The car is a 1956 Ford V8. ANY AND ALL HELP WILL BE GREATLY APPRECIATED. Thanks, Joe D |
08-04-2012, 02:53 PM | #2 |
Re: noisy engine
thats a very loaded question? First you need to determine whats making the noise and repair the problem. There is no majic fluid the fixes engine. Frank
08-04-2012, 05:02 PM | #3 |
Re: noisy engine
Frank is correct. Find out what it is or it may not be "that runs great" for very long. have you check the valve lash. Y-Block Fords had solid lifters and if not adjusted occasionally will get pretty noisy.
02-20-2013, 04:08 PM | #4 |
Re: noisy engine
My '55 V8 had a banging noise on startup that would quiet down while driving...turned out to be flex plate rivets were loose. New improved light weight replacement flex plate from Tee-Bird Products cured that problem.
02-20-2013, 04:45 PM | #5 |
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Re: noisy engine
I was going to say, the first "additive" I would try on a noisy Y-Block is a big can of valve lash adjustment.
02-20-2013, 05:09 PM | #6 |
Re: noisy engine
02-20-2013, 07:26 PM | #7 |
Re: noisy engine
I always get a chuckle when someone answers a 8 month old thread and others add to it.... Just saying.
02-20-2013, 08:29 PM | #8 |
Re: noisy engine
Y-blockhead, I know it's funny. Just bored tonite. Besides, maybe he's still at his computer, waiting for a response ?
02-21-2013, 02:49 AM | #9 |
Re: noisy engine
I found Him! it's too late!
02-21-2013, 07:02 AM | #10 |
Re: noisy engine
LOL !!! Hey, cool. There's our thread on his screen !!
03-06-2013, 06:07 AM | #11 |
Re: noisy engine
My 56 Merc also had a noise at idle when started. Originally was told that it was the Torque Convertor lacking oil. After investigating, found that it was the Rivets holding the "fingers" on the Flex Plate. Took the Flex Plate to an Engineering Shop where they tightened the Rivets. Noise now gone.
Regards Mercman <>< |
