Old 11-17-2019, 05:53 PM   #1
Travelair 3000
Default Rumble seat
I have a 1930 coupe. Does someone have a picture or description of the lower attaching hardware for the Rumble seat back cushion assembly.
I do believe my car is incorrect.
The rear cushion pushes up when closed, so when opened it disengages the upper tabs in the lid.
Thank you
Travelair 3000 is offline   Reply With Quote
Old 11-17-2019, 07:22 PM   #2
TMarsh
Default Re: Rumble seat
tabs on the bottom of the springs that attach the cushion to lid with screws
TMarsh is offline   Reply With Quote
Old 11-17-2019, 07:49 PM   #3
CT Jack
CT Jack's Avatar
T Marsh pleas provide photo of clips or tabs used to hold back rest.
CT Jack is offline   Reply With Quote
Old 11-17-2019, 09:12 PM   #4
TMarsh
do not know how to post pictures, they are just small bent over sheet metal tabs with holes in them. The tab is bent around the lower spring and screwed into a hole in the rumble lid. You cant see it hardly you have to feel for it. You slide the top clips in the slots at the top and screw the bottom tabs to the inside rumble with small screws. One on each side at bottom of spring roughly even with top slots, look for holes. Mine came attached to the springs I ordered from Snyders, but I would not hesitate to make my on.
Old 11-18-2019, 06:12 PM   #5
Travelair 3000
Do you mean the tabs attach to the springs themselves, not the seat frame?
I have tabs that attach to the lower back seat frame, not the springs.
This might be my issue.
Thanks
Old 11-18-2019, 07:47 PM   #6
TMarsh
If you are calling the bottom metal of the spring assembly then yes. I am not sure what you are calling the seat frame. The spring does not have a separate frame.
Old 11-18-2019, 11:45 PM   #7
Bill Cilker
Bill Cilker's Avatar
Here is a picture of the tab on my original 1930 rumble seat rear cushion. The tab is in the lower left of the picture
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 11-19-2019, 06:33 AM   #8
Travelair 3000
Thank you, a picture is worth a 1000 words.
I see where my issue is.
Thank all for the replies
