Old 10-17-2019, 08:10 PM   #1
bullrunmotor
Default Torque value fors 292 and pcv reccomendation
Anyone got a torque chart stating what the bolts that draw down the oil galley cover should be and also the intake manifold bolts torue values are . Also-does anyone know of what pcv valve might fit the opening where the draft tube attaches? Thanks in advance
bullrunmotor is offline   Reply With Quote
Old 10-17-2019, 08:14 PM   #2
paul2748
paul2748's Avatar
Default Re: Torque value fors 292 and pcv reccomendation
Both specs should be in the shop manual.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-17-2019, 11:35 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Torque value fors 292 and pcv reccomendation
If you don't have a manual I will post the torque values if needed.
As for the valley pan, the replacement grommets are too thick for some applications and may cause the fastener to hit the bottom of the intake.
What car and engine do have in regard to PCV?
EDIT -
Here is a torque value chart - http://yblockguy.com/techtips/yblocktorquetable.html
If not enough let me know.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-18-2019, 08:43 AM   #4
bullrunmotor
Kultutz-thanks for the torque spec on the intake manifold bolts as I don't have a manual.
do you have a publication for specs on the 2 bolts that hold the oil galley cover pan. I am thinking about replacing the oil draft tube with a PCV valve on 56 Ford Fairlane with 292. thanks again for any suggestions
Old 10-18-2019, 11:49 AM   #5
KULTULZ
KULTULZ's Avatar
Smile Re: Torque value fors 292 and pcv reccomendation
... do you have a publication for specs on the 2 bolts that hold the oil galley cover pan.
2.0 to 2.5 Ft Lbs - FORD SHOP MANUAL
Just make sure the grommet used isn't too think.
- WHY IS IT ... -
Old 10-18-2019, 12:02 PM   #6
56sedandelivery
56sedandelivery's Avatar
Ill think about it.
56sedandelivery is offline   Reply With Quote
Old 10-19-2019, 01:09 PM   #7
blucar
blucar's Avatar
A PCV system from a '63-64 292 F-100/350 is a perfect fit for all early Y-Blocks.
Bill.... 36 5 win cpe
