Old 09-27-2019, 08:40 PM   #1
thom
thom's Avatar
Default heater
Is there a heater that works with the stock exhaust manifold? If so, are they worth installing? I don't want to disturb my manifold, that doesn't leak but my wife would like to have some heat this winter.
We have one on our Model T that works with the stock T manifold.
thom is offline   Reply With Quote
Old 09-28-2019, 05:58 AM   #2
marty in Ohio
marty in Ohio's Avatar
Default Re: heater
Thom,
Snyder's has one. It's on page 188 of their catalog. Says it goes on a stock manifold without cutting or welding. It even comes with the firewall valve to control the heat. Easily removed for the summer.
Marty
marty in Ohio is offline   Reply With Quote
Old 09-28-2019, 07:07 AM   #3
Joe K
Joe K's Avatar
Default Re: heater
Problem with any of these is you have to cut a hole in your firewall. If you have the hole/valve then no problem. But something about "virgin" keeps me from installing a heater.
Holes are easy to make, but HARD to reverse.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 09-28-2019, 09:31 AM   #4
1930artdeco
1930artdeco's Avatar
Default Re: heater
There are some out there that go up through the floor boards. Also, they can work VERY well. So whomever sits in the passenger seat will get roasted.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 09-28-2019, 11:00 PM   #5
bdtutton
Default Re: heater
I have a 1930 Tudor and it is cold here in Michigan in the winter. I bought an aluminum manifold heater from Snyder's last year that bolts onto the stock manifold. It does require you to cut a hole in the fire wall, but it works well and is easy to take off in the summer.
It kind of feels like you have a hair dryer blowing into the car when you are driving down the road...Most of my trips are only a few miles so it only has time to warm the car up by about thirty degrees. So when it is 30 outside it brings it up to 60 pretty quick.
bdtutton is offline   Reply With Quote
Old 09-29-2019, 07:37 AM   #6
Standing Elk
Default Re: heater
I also have one from Snyders on my 30 coupe. I live in northern Idaho where it gets pretty cold. The heater works great in the coupe.
Standing Elk is offline   Reply With Quote
Old 09-29-2019, 07:38 AM   #7
chap52
chap52's Avatar
Default Re: heater
I have one of those Snyder type heaters... Works great... Yes it does get cold enough in Arizona to use it... Chap
chap52 is offline   Reply With Quote
Old 09-29-2019, 07:09 PM   #8
Gold Digger
Default Re: heater
when I was a kid my uncle was always coming up with a different model a. One I remember was a tudor and he had a kerosene stove tied between the back seat window cranks, worked real well as long as you could ride in the front. The other one I remember had a gasoline heater that I can't remember the name of right now "Southwind" it finely came to me. I know they were dangerous, but he lived dangerously. I've wondered how he feed gas into the Southwind. I had a 48 ford pickup that had one on it and it came out the bottom of the carb. I guess it didn't have to have any pressure. I wouldn't recommend this type of heaters.
Gold Digger is offline   Reply With Quote
