Old 10-12-2017, 03:01 PM   #1
fredski53
fredski53's Avatar
Default Drag link rubbing tie rod
My 31 Victoria has binding in the steering. I've adjusted the sector, now I've noticed the drag link is rubbing on the tie rod! I've read where if there's a 1/4 inch space between the bottom shackle and the top of the axle then the spring is good. I have a good 1/4 inch space there. Should the shackles be replaced? Would that keep the the two from rubbing? Thanks, Fred
fredski53 is offline   Reply With Quote
Old 10-12-2017, 03:29 PM   #2
Ed in Maine
Default Re: Drag link rubbing tie rod
I'm guessing but you may have an incorrect pittman arm attached to the steering gear box. Compare what you have with another Model A. You may have a 32-34 part. I don't think spring shackle wear would be enough to cause this interference. Ed
Ed in Maine is offline   Reply With Quote
Old 10-12-2017, 03:35 PM   #3
SeaSlugs
SeaSlugs's Avatar
Could be a weak spring, broken leaves, bent frame, bent steering balls as well.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 10-12-2017, 04:23 PM   #4
montanafordman
montanafordman's Avatar
I had all of those when I first got my model A. The wishbone was bent, the tie rod bent, etc. The funny thing was that when the axle, frame, wishbone everything was corrected i noticed that the replacement rebuilt steering arms I ordered had one bent on the passenger side. The vendor made it right and I got a good one and my car drives nicely and does not wander, have excessive play, or a death wobble.
Aaron in Tacoma
(although still a Montana hillbilly at heart )
montanafordman is offline   Reply With Quote
Old 10-12-2017, 04:55 PM   #5
Bob C
The later pitman arms are splined not square.
Bob
Old 10-12-2017, 08:03 PM   #6
SteveB31
SteveB31's Avatar
Front spring is flat
SteveB31 is offline   Reply With Quote
Old 10-12-2017, 08:24 PM   #7
larrys40
Agree I would say spring needs replacing
Larry Shepard
larrys40 is offline   Reply With Quote
Old 10-12-2017, 09:28 PM   #8
SeaSlugs
SeaSlugs's Avatar
post a side and front picture of your car on level ground and we can probably tell if the car is sitting right.
Old 10-12-2017, 09:34 PM   #9
Larry Jenkins
Broken vertical center bolt in the front spring. Had one..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Thread Tools
Display Modes
