Old 10-02-2019, 06:52 PM   #1
Mac VP
Mac VP's Avatar
Default The Defiant One.....at the transmission shop
We had one of the most rusted stubborn transmissions ever to grace our shop. This toploader was so dry and stuck that nothing would move or rotate. Many blows with a punch and the BFH would not budge the 7111 countershaft from the case. The customer agreed to scrap it and we're building one from our parts stock.
Today, my helper Will Kimble, asked if we might try moving the shaft by using our 20 ton press. We set it up and cranked the press handle. The press groaned and grunted and finally the shaft moved inward. That shaft moved allright….check out the results. Just confirmed to me that we made the right call to scrap it !
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 10-02-2019, 06:55 PM   #2
JSeery
JSeery's Avatar
Default Re: The Defiant One.....at the transmission shop
Little superglue or epoxy should fix it right up!
Old 10-02-2019, 07:24 PM   #3
Andy
I have used candle wax to separate severely rusted parts. It is magic.
Andy is offline   Reply With Quote
Old 10-02-2019, 07:36 PM   #4
39portlander
39portlander's Avatar
Mac, you see those on craigslist "pulled from a known running drivetrain 20 years ago, kept in dry storage"
39portlander is offline   Reply With Quote
Old 10-02-2019, 07:45 PM   #5
Mac VP
Mac VP's Avatar
Oh it was dry alright.....notice the crud in the front ball bearing.
VANPELT SALES LLC
Cincinnati, Ohio
Old 10-02-2019, 08:15 PM   #6
skidmarks
skidmarks's Avatar
Light pressure and a little heat might.have saved that case
skidmarks is offline   Reply With Quote
Old 10-02-2019, 09:24 PM   #7
51504bat
51504bat's Avatar
JB Weld?
Old 10-02-2019, 09:38 PM   #8
petehoovie
petehoovie's Avatar
Old 10-02-2019, 11:06 PM   #9
Talkwrench
Talkwrench's Avatar
Original counter shaft tight fit
Old 10-03-2019, 12:10 AM   #10
RalphM
RalphM's Avatar
That’s pretty ugly!
RalphM is offline   Reply With Quote
Old 10-10-2019, 04:05 PM   #11
alchemy
alchemy's Avatar
I bet that shaft didn't weep any lube. Rust seals up any loose fitting hole.
alchemy is offline   Reply With Quote
Old 10-10-2019, 04:25 PM   #12
Mac VP
Mac VP's Avatar
....I’d bet it’ll leak out the front now!
VANPELT SALES LLC
Cincinnati, Ohio
Old 10-10-2019, 04:49 PM   #13
5851a
I've had redi strip do some amazing things to rusty stuff, at least it was to me. But the time I took parts in turn around was months and I wasn't in a hurry then. Would there have been anything salvageable inside that case?
5851a is offline   Reply With Quote
Old 10-10-2019, 08:07 PM   #14
Mac VP
Mac VP's Avatar
Well I highly doubt it. Every gear and shaft was severely rusted and pitted. Nothing would move. We’d sprayed it thoroughly with PB Blaster but nothing budged after several days. We still thought we’d at least perhaps save the case. This was where we hit the roadblock of that stuck countershaft. I had to weigh the extra hours of work trying to clear the gearbox versus simply pulling a good set of gears and a decent case from our stock. Of the hundreds of rusted gearboxes we’ve encountered, this was the first one to successfully defy us.
VANPELT SALES LLC
Cincinnati, Ohio
Old 10-10-2019, 08:49 PM   #15
tubman
tubman's Avatar
If I had a transmission like this, I would have dumped it into a bucket of "Rust-911" solution and let it sit a couple of days. You might be surprised with the results.
(I much prefer "Evaporust", but the economics are just not there in this situation.)
Old 10-10-2019, 08:56 PM   #16
Tinker
Tinker's Avatar
Or a tub of used oil for a yr. I've had decent luck with the new pb blaster stuff, as getting kroll isn't easy for me. This one would take a lotttt of soaking.
Even if you free it maybe too pitted due to neglect?
Old 10-10-2019, 09:21 PM   #17
dumb person
dumb person's Avatar
I've freed worse. Took many months of soaking in oil, and a few heat cycles. But they can be freed eventually.
My favourite spanner was found on a beach encrusted in rust with sand & shells sticking out of the rust blobs.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 10-10-2019, 09:39 PM   #18
Tinker
Tinker's Avatar
Guess the lesson is to when storing don't keep it out side or fill it with oil and spray the sh!t out of it ever season. Maybe inside also.
Old 10-12-2019, 04:54 PM   #19
AKCJ
Thanks for sharing Mac.
AKCJ is offline   Reply With Quote
