11-01-2019, 01:58 PM | #1 |
Mysterious hole in valve chamber?
Hallo,
I have an uncertain question. After opening the valve chamber, I discovered a strange hole in the front open to the timing gear chamber. It looks like a very irregular breakthrough. Is that correct? Thank you all for helpfull answers.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
11-01-2019, 02:06 PM | #2 |
Re: Mysterious hole in valve chamber?
It is ugly and not the German way. The pathway for oil to flow over the timing gears. One place where labor money was saved. The guy who bashed the hole there in the block only had time for two hits with the hammer. Those who have used a die grinder to detail the ragged edges never saw an improvement but they slept much better.
11-01-2019, 02:08 PM | #3 |
You can see a similar hole here in this block being rebuilt:
11-01-2019, 02:10 PM | #4 |
Hi Werner
No, that does not look correct! In mid May a hole [3/8"] was provided to get extra oil to the rear cam bearing & earlier blocks were sometimes drilled for this, but not to timing gears. Looks like someone had a mishap or misguided attempt to improve lubrication. I personally would not worry ; at a later time if you have to take the engine down, you could get it fixed. Cheers. |
11-01-2019, 02:13 PM | #5 |
I too, have seen a number of blocks that look about like this one in question. I have heard that that is just how the were!
11-01-2019, 02:32 PM | #6 |
Worked on many Model A engines and never saw one without the busted out hole above the timing gear.
I noticed the harder I work the luckier I get! |
11-01-2019, 02:33 PM | #7 |
Normal.
Paul in CT |
11-01-2019, 03:54 PM | #8 |
Perfectly normal from what I have seen in many engine blocks. It might be a crude way of doing things but IT WORKS. What else do you need?
11-01-2019, 04:19 PM | #9 |
Normal. Ford did vary the positioning of the hole to vary with a change in valve chamber oil "level." This occurred about the time the timing cover oil return pipe was lowered - ostensibly a move to "reduce oil consumption." August 1929 IIRC.
Steve Plucker may have information on this - he's done a "type study" on block details - I think it's online. Joe K
Shudda kept the horse. |
11-01-2019, 04:45 PM | #10 |
Here is a picture of the hole, seen from the timing gear side, taken when my engine was being rebuilt.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
11-01-2019, 09:56 PM | #11 |
Steve Plucker's "type study" of Model A Engine Blocks is "ongoing."
Joe K http://www.plucks329s.org/studies/studies.htm
11-02-2019, 03:39 AM | #12 |
Thank you all for the helpful hints about the "mystic hole". I am calm now! -
At Steeve Plucker "Pluck": What extraordinarily valuable diligence works!
11-02-2019, 07:29 AM | #13 |
The hole was in the casting pattern, and not bashed-in. Having taken apart many engines, the hole in question is rarely nice and round. More often it is irregular.
The concern with an irregular hole in the block casting is that the bottom of it is about level with the top of the nearby lifter bore. If the hole extends too low, it lowers the oil level in the valve chamber, so I paste a piece of sheet metal with a round hole in it to the front wall of the valve chamber. JB Weld works well for this fix.
Bob Bidonde Last edited by Bob Bidonde; 11-02-2019 at 07:37 AM. |
11-02-2019, 07:32 AM | #14 |
Ive knocked a lot of those holes in v8 blocks at the Cleveland Ford Casting plant. We used an air tool with a round chisel designed for that job RAY
11-02-2019, 07:49 AM | #15 |
Restorer magazine jan/feb 1998, pg 22, one full written page on busted out hole in valve chamber. The hole must be higher than the first dam in order for the oil to build up and run back over the first dam to get to the center and rear main. The article states that most likely it was busted out to facilitate replacing timing gear. When I rebuilt my engine I followed the instructions, used a piece of flat metal 1/8 x 1 x 2 drilled one hole 1/4" it, and one hole the web of busted out area, fastened to web with a 1/4" bolt and jb weld, just above the level of the first dam. Then drilled another hole below the top of the new dam, 5/16 diameter to feed oil to the timing gear.
11-02-2019, 02:34 PM | #16 |
Hello everybody,
I thought again. (Last night, the whole day ...) I can not believe that the breakthrough was "just hit somewhere" inside. Because then the correct height of the overflow for the oil pipe is at the wrong (too low) level. I measured it. 1) The lowest overflow edge from the return opening in the valve cover. 2) The lower edge of the breakthrough. I have marked marks outside. (see picture) It can be clearly seen that the lower edge of the break hole is about 1/4 inch below the discharge edge of the return pipe. Then the return pipe would make no sense, because the oil level does not reach the return opening.
11-02-2019, 02:58 PM | #17 |
Don't forget the rear of the engine sits lower than the front.
Bob |
11-02-2019, 06:10 PM | #18 |
There is no return pipe, the pipe you see is the oil supply, the oil returns over top of the front dam.
11-02-2019, 10:14 PM | #19 | |
The black pipe on the outside of the engine from the valve cover to the block is indeed a oil return. Where would the oil go when driving up a long hill?
11-03-2019, 08:45 AM | #20 |
It would all go to the center and rear main then to oil return pipe on outside engine. Another question might be where would all the oil go on a long down hill run if the jagged hole was too low.
