03-18-2018, 02:25 AM | #1 |
'55 T-Bird slow warm up
My '55 T-Bird takes forever to warm up. I just replaced the thermostat because I figured it must be missing, since it takes so long.
Turns out it had a 160 degree already in it, which I replaced with the recommended NAPA unit which is 170. Drove about 4 miles before my aftermarket temp gage started to move. Am I Just spoiled from driving newer cars? My 06 Jeep Wrangler would be at operating temp after one mile easy. It is a fairly stock 292 with some more modern touches, carb, ignition,etc. It doesn't start to overheat unless it is 100, in stop and go traffic. Thank you, Someday I will get all the bugs out. |
03-18-2018, 08:37 AM | #2 |
Re: '55 T-Bird slow warm up
Sounds normal to me. Y-blocks are notoriously cold hearted. Modern cars heat up much quicker for emissions reasons; the system goes into open loop quickly to allow the ECM to lean the injectors. None of this was a consideration when our cars were built. Modern vehicles also tend to have aluminum blocks and/or heads, another reason they heat quicker than a huge lump of cold cast iron. You can block off part of the radiator with an appropriately sized piece of cardboard to warm it faster, just don't forget to remove it when the engine reaches operating temperature.
Often wrong but never in doubt. |
03-19-2018, 08:10 AM | #3 |
"Am I Just spoiled from driving newer cars? "
Yes, new cars and trucks are designed for better heater and A/C performance, due to the ever spoiled customers and competition. Sal |
03-19-2018, 09:44 AM | #4 | |
Do you mean you have poor heater output in colder weather? You need a 180 thermostat. TECH ARTICLE HERE- https://www.ctci.org/gilsgarage/Thermostats2.php Now if the thermostat causes overheating in the summer, you merely change it back to 160 in the spring. That was how it was done on the old days. Also remember, the engine needs to operate at a certain minimum temp for the oil to work correctly, especially if road draft equipped.
***** - MULTI-VEHICLE SYNTHETIC TRANSMISSION FLUID - Multi-vehicle transmission fluids are becoming more and more popular in the marketplace. Oil marketers design these fluids for a wide range of automatic transmission types. While they are not licensed by any specific auto manufacturer ... ??? ... enough said ... DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
03-19-2018, 09:53 PM | #5 |
The other thing I’ve found on my bird is the heater valve really doesn’t close completely. So even in warm weather, with it off, you’re running the heater too. And if the seals are leaking on the air pick up (which they do), you’ve got some heat going into the interior too.
03-19-2018, 10:20 PM | #6 | |
03-20-2018, 01:51 AM | #7 |
Heater? Where I live, I hardly use the heater on my newer cars. It was about 60-65 on the day in question. The top is not on either. I cannot stand driving it with the top on. Struggle to get in, then I can't see out. Don't mean to come off sounding like a wise ass, just clarifying. If I had to leave the top on, the car would be gone.
I have to go look to see if the heater hoses are even on the car. I don't think so. If they are I will look into mikers suggestion. Thanks for the suggestions. Leaving tomorrow for my Grandaughter's wedding Saturday on the beach at Camp Pendleton. Won't be able to check it for a while. |
03-20-2018, 03:17 AM | #8 | |
Had a 67 GT-500. Same thing, hard to get in and out. Now the things are worth a fortune... If the heater is not a concern, most likely lazy thermostat and/or the WP bypass needs to be restricted.
03-21-2018, 06:04 AM | #9 | ||
It seems quality valves are not being produced any longer and the ones still available are low quality off-shore. NOS is questionable. I stumbled across this while browsing through their catalog. I always hated the appearance of the valve as it made the car look old tech to me. I guess the dedicated could re-insert the valve if showing the car. http://www.classictbird.com/Manual-H...tinfo/18495MK/ Quote:
03-24-2018, 09:52 AM | #10 | |
03-24-2018, 01:39 PM | #11 |
Restrict the heater by-pass hose
