Old 10-08-2012, 02:41 PM   #1
293131
Default PLEASE HELP - 1931 Cabriolet noise identification
Hello, everyone. I am trying to help my dad out in finding a noise he hears only at certain RPMs. I haven't heard it, but from what he said, it almost sounds like a metal to metal grinding.
He thought it was the transmission. He had it replaced and it still makes the sound. He thought it was the engine and he replaced it with a rebuilt engine. No change. He changed out the speedo cable and no change. He feels as though he is running out of things replace. He is not a mechanic, but has a knowledgeable one who at this point can't find the noise either.
Any suggestions? If you have any thoughts, I would love to hear them. You may email me at wmleiv(at)yahoo(dot)com - spelled out for all of the spammers out there. Thanks again for your help. I look forward to hearing from you.
293131 is offline   Reply With Quote
Old 10-08-2012, 02:42 PM   #2
Jason in TX
Jason in TX's Avatar
Default Re: PLEASE HELP - 1931 Cabriolet noise identification
can he take his phone and take a video and then post it?
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 10-08-2012, 02:44 PM   #3
293131
I will try to do this and post it. Someone mentioned that it might a poorly positioned flywheel.?
Old 10-08-2012, 02:57 PM   #4
Aerocraft
Aerocraft's Avatar
How about the rear axle? Gar Williams
Aerocraft is offline   Reply With Quote
Old 10-08-2012, 03:03 PM   #5
293131
Thanks. He typically hears it only with certain RPMs but it is typically always under load. I don't know if that helps out or not.
He had disconnected the speedo and ran it that way and it still made the noise so he was able to eliminate that.
What specifically is the mechanic to check for in the rear axle? Is there a common weak area there? Thank you again.
Old 10-08-2012, 05:17 PM   #6
Raven
Does the muffler have a heat shield on it? Even though you say the noise is grinding could it be a vibration?
Raven is offline   Reply With Quote
Old 10-08-2012, 07:19 PM   #7
Benson
Benson's Avatar
If it is a grinding noise maybe the four flywheel bolts are too long and are scrapeing on the engine block.
Also if the flywheel dowel pin retainer is missing then the correct length bolts can sometimes stick out too far and scrape on the engine block.
Flywheel dowel retainer looks like this:
http://parts.modelastore.com/show_Product.asp?ID=3739
Old 10-08-2012, 08:06 PM   #8
293131
Thanks for all of the answers, everyone. I am fwding these to my dad so he can let his mechanic know.
Great stuff. Thanks again!
Old 10-08-2012, 08:12 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Also, too long a starter mounting bolt can hit the flywheel.
Old 10-12-2012, 03:37 PM   #10
293131
UPDATE and follow-up question -
I rode in this Model A today and I don't think it's metal to metal grinding at all. To me, it's more like a heavy vibration. You can feel it in the steering wheel, etc... But it's still really only under load/acceration.
If this changes suggestions, I'd love to hear them
Thanks!
Old 10-12-2012, 05:59 PM   #11
Greg Jones
Greg Jones's Avatar
Well here is the standard answer: "Could be a lot of things." Of course, that is not helpful. How is your timing? Are you sure it is timed right? Sometimes I have seen cases where timing is set too far advanced, the car will rock and roll and it feels like it is coming from the flywheel (which it is). A Model A timed right should idle with the spark lever no more than halfway down the quadrant (and that is a bit much in my opinion). For general running on the highway spark lever should advance about 2/3 of the way down the quadrant. Only when running at self-destruct speeds should the spark be fully advanced. Now, this is with Snyder and Brumfield 5.5 and 5.9 heads which require less advance. I ramble on about this just to ask if maybe your Dad is running too advanced at low speeds, such as at idle?
Greg Jones is offline   Reply With Quote
Old 10-12-2012, 06:07 PM   #12
293131
Thank you. I think the timing is okay. It was idling beautifully with the spark lever all the way up. I don't know if it would help with a recording or not. I will try to do that.
Thanks again for all the help. This is a great forum.
Old 01-09-2013, 09:49 PM   #13
mebeached
sounds more like a wheel bearing to me if you changed the motor and trans not much left
mebeached is offline   Reply With Quote
Old 01-09-2013, 09:55 PM   #14
Fred K-OR
Fred K-OR's Avatar
Bad brake situation on one of the wheels????????
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-09-2013, 10:13 PM   #15
Phil
Phil's Avatar
Has it been run on jack stands?
Phil is offline   Reply With Quote
Old 01-09-2013, 11:17 PM   #16
Pete in Michigan
Pete in Michigan's Avatar
When I got my dad's Model "A", it had a metal to metal grinding sound that was caused by the " Throttle Control Assembly" pivit arm rubbing on the bottom edge of the firewall. Replaced assembly, noise gone.
Another vibration at certain RPMs was caused by a hood rod nut that bottomed out before being tight to the bracket at the firewall. Make sure nothing is loose or rubbing on firewall. The firewall is like a sound board in a piano, it amplifies noises.
Pete in Michigan is offline   Reply With Quote
Old 01-10-2013, 01:47 AM   #17
Hicktick
Hicktick's Avatar
If you tell us where your father is at , maybe someone is close and could run by and help .
Just a thought , you never know the power of the barn .
Hicktick is offline   Reply With Quote
Old 01-10-2013, 11:06 AM   #18
1936ford64
May be a harmonic vibration, such as a choke rod with out a bushing.
1936ford64 is offline   Reply With Quote
Old 01-10-2013, 02:23 PM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
293131,
Dog here, havent rode the Model A yet, but smart a**ed Bill says, "Welcome to the world of Model A noises, BRR, GRUMP, BUZZ, ZIDDLE, RAORR, ETC"! Like, "What's that new noise?? I didn't hear it yesterday! Is something goin' to break?" "NAW! it's just Model A FUN"!! Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 01-10-2013, 03:30 PM   #20
Bruce Adams
Bruce Adams's Avatar
293131,
WHERE are you located?
There are Model A people all over the world, many of whom will be pleased to assist you.
Replacing major components without a proper diagnosis is not the most effective way to get the car running right.
Good Luck !
Bruce Adams is offline   Reply With Quote
