Old 03-04-2021, 11:55 AM   #22
jason78613
jason78613's Avatar
Default Re: carb leaking gas, what did I do wrong?
Originally Posted by 51 MERC-CT View Post
Pull the float to determine if it has gas in it.
Ok, that will be my next task.
EDIT:
Ah ha! I just removed the carb off the car and pulled out the float and gave it a shake... sure enough, it's full of gas! I wiped it dry and I can see gas seep out immediately... I guess a new float is in order!
At least I now know what the culprit is. (probably could've found it a lot sooner but I'm still learning so always afraid of taking things apart and risk making it worse, or not being able to put it back together correctly.)
Thanks everyone!
jason78613 is offline   Reply With Quote
