Old 08-23-2012, 05:20 PM   #1
bgarrett
bgarrett's Avatar
Default 1950 Ford disc brakes
The kit on ebay looks appealing but what power booster do you guys recommend?
http://www.ebay.com/itm/1949-1950-19...9a4d2c&vxp=mtr
bgarrett is offline   Reply With Quote
Old 08-23-2012, 05:22 PM   #2
Butch11443
Butch11443's Avatar
Default Re: 1950 Ford disc brakes
Think you had better check in on the HAMB for this one.
Butch
Butch11443 is offline   Reply With Quote
Old 08-24-2012, 01:15 AM   #3
wga
wga's Avatar
Check JAMCO, in Corona, Ca.
Henry Ford designed the flathead without the aid of a computer.
wga is online now   Reply With Quote
Old 08-24-2012, 02:16 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Most likely Ebay item is a Jamco unit being sold by re-seller.
As stated check Jamco here---
http://www.jamcosuspension.com/produ.../productID/458
Old 08-24-2012, 10:40 AM   #5
bgarrett
bgarrett's Avatar
There have been many posts advising to stay away from Jamco.
My question was: Which booster to use with the ebay kit?
Old 08-24-2012, 12:41 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
It,s not just the booster you need, it,s the dual master/booster pedal assy. Jamco has it. I have a Jamco disc brake assy in my Merc. along with someone else's dual master/7" booster pedal assy. Never had a problem with Jamco.
See here for ford assy.---
http://www.jamcosuspension.com/products/productID/69
Old 08-24-2012, 08:55 PM   #7
bgarrett
bgarrett's Avatar
It is really frustrating when I speak clear distinct Standard English and all the responses totally avoid an answer.
The question is WHAT BOOSTER?
Old 08-24-2012, 09:10 PM   #8
TJ
TJ's Avatar
There's two types of boosters. Single diaphram and dual diaphram. Either one will work on your car. If you are leaving the pedal assembly under the floor you can only use the 7" booster. You would be fine with the single diaphram type.
Old 08-25-2012, 04:29 AM   #9
34PKUP
34PKUP's Avatar
You obviously don't even know what a seven inch booster is.
If you checked any of the Jamco reccomended sites you would see WHAT BOOSTER to use. And if you go to this site you will find several that are suitable for your application ( that is if you are capable of reading Standard English)
http://www.ebay.com/sch/i.html?_trks...oster&_sacat=0
34PKUP is offline   Reply With Quote
Old 08-25-2012, 04:43 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
If you had checked the Jamco site you would have seen (in Standard English) which booster to use.
See here---
http://www.jamcosuspension.com/produ.../productID/706
Old 08-25-2012, 04:53 AM   #11
Fibber Mcgee
Fibber Mcgee's Avatar
I believe they were just trying to help you not make a bad decision.I'd rather have someone warn me of a bad product than just let me buy it and waste my money.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 08-25-2012, 09:27 AM   #12
flathead4rd
flathead4rd's Avatar
WOW! No need to get testy here. This is the Ford Barn... Not the HAMB.
flathead4rd is offline   Reply With Quote
