02-01-2019, 09:34 AM | #1 |
1947 Ford frame question
I have a 1947 ford coupe complete chassis, and I was wondering if the frames are the same from 1941 to 1948, and would they accept a pick up body and bed and fenders and what years would work. And if so would anybody have a pick up body/bed/ fenders etc. available. If not then I would put this chassis up for sale.
Thanks ahead of time for your expert opinions. Ron. |
02-01-2019, 09:43 AM | #2 |
Re: 1947 Ford frame question
41 is a different animal, pickups and car frames were same in 41.
42 to 48 cars were the same, but the pick up had a completely different frame. They will not interchange. |
02-01-2019, 10:49 AM | #3 | |
Guys; 1941 commercial (pu & vans) used 1940 frame --not 1941 Car frame Love these old Fords! Gene Tulsa Last edited by G32; 02-01-2019 at 10:52 AM. Reason: correct figure |
02-01-2019, 01:04 PM | #4 |
They are similar but the 1941 passenger vehicles still had the crankshaft mounted fan with the low radiator mountings on the front. The commercial pickups started out with a frame that was similar to the 1940 frames but the front cross member changed for the 6-cylinder engines. The 1942 commercial pickup had open drive so its a lot different than 1941. The cab on the jail bar trucks is similar to the cabs on the earlier commercial vehicles before the open drive change but it takes a good bit of work to use it on one.
02-01-2019, 01:06 PM | #5 |
The 41-48 passenger frames are virtually the same with some minor differences. The 42-47 pickup frames are totally different from the passenger frames.
02-01-2019, 03:11 PM | #6 |
02-01-2019, 03:17 PM | #7 |
41 car frames, there is a early and a late for 1941
The frames are too wide to 'build"a custom truck using a 47 and early truck cab and sheetmetal on a 1941 or 1942 to 47 passenger car frame. The cab wont sit down over the rails like it does on the 35 to 40 chassis. |
02-01-2019, 04:35 PM | #8 |
same cab from 1940 to 47. 40/41 used a car frame very similar to a car, but without the outside frame body mounts. 42 to 47 truck frames are of the "ladder bar" style, no x frame just two parallel rails with cross members, yes you can mount a 40/47 ford truck cab on any of these frames, the mounting blocks, etc are different. If you can't do this don't tell my 41 truck because it has a 47 cab
02-01-2019, 10:14 PM | #9 |
Thanks guys, would any body be interested in a 1947 ford coupe complete chassis, it is a 6cylinder chassis with every thing from the radiator to the gas tank with original wheels trim rings and hub caps brakes all work and also the complete steering column with a very nice steering wheel.
Thanks Ron. |
02-02-2019, 12:52 AM | #10 |
Post it in the swap meet, you may find a buyer
02-02-2019, 04:22 AM | #11 |
Ron, as you can see from my Avatar, I'm partial to '47 coupes. Do you have no interest in restoring it as a coupe? It would be a lot more valuable and perhaps you could parlay it into that truck your after??
