07-21-2018, 11:05 PM | #1 |
Window Riser Handles
I am working on a late 1931 coupe with split window riser shafts that require the pointed set screws for securement. The vendors seem to only have the handles that are secured with pins. Do I need to cut threads into the pin holes or what? Any suggestions?
07-22-2018, 11:28 PM | #2 |
Re: Window Riser Handles
Have you asked several vendors?
Someone must have the correct style, as I've seen them before. |
07-23-2018, 11:28 AM | #3 |
Right, Tom! I do need to research this further. I have been using Bratton's for so long I forget about the other vendors.
07-23-2018, 12:11 PM | #4 |
Bert's in Denver.
07-23-2018, 07:14 PM | #5 |
Local Auto Upholstery Shops usually have a "junk" box of various fasteners! AND, they know ALL the "TRICKS"
Bill Scrounge
07-24-2018, 01:14 PM | #6 |
Paul in CT |
Thread Tools | |
Display Modes | |
