Old 04-08-2018, 09:03 PM   #1
modela4shane
Default Axle End Play, Thrust?
Can anyone tell me what controls the axle end play in the model A differential? I have excessive play on both axle and the drums rub on the backing plates. What needs to be replaced or fixed or is this problem adjustable when rebuilding the rear end?
Thank you in advance.
modela4shane is offline   Reply With Quote
Old 04-08-2018, 10:53 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Axle End Play, Thrust?
To start, is the axle nut tightened to 100 foot lbs?
Old 04-08-2018, 11:03 PM   #3
daveymc29
daveymc29's Avatar
I have two cone spacers on one of my coupes. That sets the wheel outboard enough to make up for some wear so that the baking plate is free of the drum. My roadster has hydraulics and back when I owned a brake lathe I turned the backing plates and took an eighth off the side toward the drum. Do not need the cone shims on that one. My other coupe gets by with one cone on each side. When I rebuild the differentials, if I ever do again, I will fix the problem, but the cones work swell and have never had one fail. JMHO
daveymc29 is offline   Reply With Quote
Old 04-09-2018, 06:55 AM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Are you talking about actual end play, in and out, or just the up and down movement that is normal?
Jacksonlll is offline   Reply With Quote
Old 04-09-2018, 07:12 AM   #5
Keith True
Keith True's Avatar
The actual end play is fixed,not really adjustable unless you get creative with machining shims and such.The back side of the axle gear rides on a machined surface on the inside of the carrier assembly,and the axle gear rides on the spider gears.Plus,there are little pads on the axle and spider gear shaft to hold it all in place.Nothing on the outboard has anything to do with end play.If the carrier bearings are loose the whole thing will slide back and forth,but that is not end play.It will give the same effect,or problems though.
Keith True is offline   Reply With Quote
Old 04-09-2018, 08:34 AM   #6
Dave in MN
Dave in MN's Avatar
If the inside surface of the axle is worn, you may have excessive end play. It is a bit rare for this condition to exist but I had it on my 1928 Pickup. At one time, my pickup was likely used to power a stationary piece of equipment by blocking up one side of the rear axle and attaching a pulley or other device to the wheel or hub to transmit power. One of the axles was severely worn along with the spider gears and the actual carrier. I had a bit over 1/8" end play on the passenger axle.
So you may need to find replacement axles, spider gears and carrier as I did.
Good Day
Dave in MN is offline   Reply With Quote
Thread Tools
Display Modes
