Old 08-14-2017, 05:23 PM   #1
modela4shane
Default 1928-29 Dash Light. Dumb Question!
This is my first 1929 vehicle, how do you turn on the dash / instrument light? 30-31 has a small switch under dash rail but i do not see anything for the 28-29. Sorry if this seems like a dumb question.
modela4shane is offline   Reply With Quote
Old 08-14-2017, 05:37 PM   #2
RawhideKid
Default Re: 1928-29 Dash Light. Dumb Question!
Place your thumb and forefinger on the cap and push in while twisting clockwise slightly.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 08-14-2017, 06:19 PM   #3
modela4shane
Thank you!
Old 08-14-2017, 07:40 PM   #4
jm29henry
jm29henry's Avatar
Rawhide has got it right
jm29henry is offline   Reply With Quote
Old 08-15-2017, 09:53 AM   #5
Jeff/Illinois
Jeff/Illinois's Avatar
No such thing as a dumb question here buddy. Better than breaking something. I've asked plenty myself.
Yes do as Rawhide says, takes a one-quarter turn reverse to shut off you will feel it 'pop out' when it is off.
Been a long time since I changed that bulb, but I think when it is 'off' you just grab the cover with your thumb and pointer finger and pull it off straight back towards you? I last changed that bulb in about 1978 so been awhile
Jeff/Illinois is offline   Reply With Quote
Old 08-15-2017, 10:58 AM   #6
Art Newland
Art Newland's Avatar
Someone here on the Barn mentioned he ran a wire up from the tail light so the dash light came on with the lights... and he put a 12 volt light bulb in it as the 6 volt one is pretty bright.
Art Newland is offline   Reply With Quote
Old 08-15-2017, 01:53 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If you have a HIGHER candlepower bulb in your dash light, turn it off QUICKLY, or it will burn the CRAP out of your finger tips!!!
IF it flickers while driving, just add a bit of solder to the bulb tip. (TIP#11)
Bill Blisters
"THE ASSISTANT GURU OF STUFF"
Old 08-15-2017, 02:06 PM   #8
RawhideKid
Bill Blisters
I run an White LED bulb in mine, but then, I'm running 12v too!!
Kool RawhideKid
