just got done trying to work with the hood hinge supports on the car got them from B drake. the box lists them for late model 41 but the hood never changed over the year. first off they cant even send the nut with the parts that hold the bracket to the car. (come on guys) then it mounts differently witch looks better. but that stops here. the hood goes up to far. and spreads the hood so it will not fit properly and won't come down all the way tried all adjustments with no good results. and the one nut and bolt that was sent the bolt was 1/2 and the nut was 12 mm.....guess I will have to re work the old stuff its probably better anyway. now I can try to get them replaced that might be a treat...
just venting thanks for lessoning..
4 ford
