03-03-2015, 07:53 AM | #1 |
head stud sealer
on a flat head what type of sealer is best to use on the head studs?? that go in the block
03-03-2015, 08:12 AM | #2 |
Re: head stud sealer
#2 Permatex works for me.
It's non hardening & handles re-torquing well. |
03-03-2015, 08:23 AM | #3 |
I use PTFE stuff - usually ARP:
http://www.summitracing.com/parts/arp-100-9904 I also coat the sides of the studs with anti-seize. |
03-03-2015, 08:51 AM | #4 |
#2 Permatex. You can get it at any parts store.
03-03-2015, 09:16 AM | #5 |
thank you!! do you torque the studs? or just get them tight?
03-03-2015, 10:52 AM | #6 |
03-03-2015, 11:28 AM | #7 |
I prefer #2 or Aviation Permeated. Some folks like to use Teflon tape. I also like the idea of using Anti-seize on the sides of studs. I like to use a thread cleaning tool to clean the internal threads in the deck prior to installing studs. NEVER USE A THREAD CUTTING TAP or DIE on these threads! Then I install studs hand tight, without torquing them.
