Old 06-07-2021, 05:07 PM   #1
rfitzpatrick
Default Shot The Carburator
I used a lazier-gun to shoot the carburator, lines, and fuel-bowl after a 10 mile drive in South Florida weather and found averages of 154 degrees.
When I asked our club about theses figures? They expressed shock.
Now, I'm not experencing a problem, I just like an opinion. What is your information about the temps?
Thanks
rfitzpatrick is offline   Reply With Quote
Old 06-07-2021, 06:20 PM   #2
GerryAllen
Default Re: Shot The Carburator
I will shoot mine on a ten mile drive and see what my temps are.
GerryAllen is offline   Reply With Quote
Old 06-07-2021, 06:39 PM   #3
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What was the ambient temp?
Old 06-07-2021, 06:54 PM   #4
McMimmcs
McMimmcs's Avatar
why did you shoot it in the first place ?
Old 06-07-2021, 07:00 PM   #5
Anteek29
Anteek29's Avatar
In a fit of anger?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-07-2021, 07:28 PM   #6
Mister Moose
Mister Moose's Avatar
I shot the Carb, and the Carb won....
Mister Moose is offline   Reply With Quote
Old 06-07-2021, 07:34 PM   #7
rfitzpatrick
OKAY - Guys
" -- But I Did Not Shoot The Deputy--"?
Old 06-07-2021, 09:21 PM   #8
CT Jack
CT Jack's Avatar
I think you mean you aimed an infrared temperature sensor or gun at the carb, lines etc. to see how hot they get.
CT Jack is offline   Reply With Quote
Old 06-08-2021, 07:57 AM   #9
Jack Shaft
Exhaust manifold heat is transferred to the intake manifold to control icing and aide combustion. Look where Ford bolted the manifolds together, its a good sized transfer area.
Often the complaints of vapor lock and fuel boiling in the carb can be traced to improper timing creating high exhaust temperatures which are transferred.
Old 06-08-2021, 10:15 AM   #10
katy
katy's Avatar
Thanks
Sounds good to me.
katy is online now   Reply With Quote
