08-26-2019, 07:27 AM | #1 |
'40 O1A-2473 pedal - shaft
Can the shaft in the pedal casting on the '40 be removed ? If so is the shaft available ? Thank you Fordbarners
08-26-2019, 07:32 AM | #2 |
Re: '40 O1A-2473 pedal - shaft
Yes and new ones are available. Just make sure when you press in the new one it’s equal on each side for the pedals
08-27-2019, 06:41 AM | #3 |
Does someone like Fred Wilner at SSO have those shafts ?
08-27-2019, 09:20 AM | #4 |
Might check with Van Pelts also.
08-27-2019, 09:47 AM | #5 |
And support the bracket when you press the new one in and the old one out.
It's not super tight I think the last one I changed I got the shaft from Dennis carpenter |
08-27-2019, 07:15 PM | #6 |
08-27-2019, 11:34 PM | #7 |
[QUOTE=skidmarks;1792505]And support the bracket when you press the new one in and the old one out.
It's not super tight I think the last one I changed I got the shaft from Dennis carpenter[/QUOTe That last sentence could be taken the wrong way
I dig coal, which provides motivation for EVs. |
08-28-2019, 06:07 AM | #8 |
[QUOTE=1952henry;1792738]Right, but if was to be taken that way. A more accurate depiction would replace Carpenter with Drake or Speedway motors.
08-28-2019, 02:49 PM | #9 |
True. Wasn't meant as jab to dc.
Thread Tools | |
Display Modes | |
