Old 08-20-2019, 08:12 PM   #1
linkpin
Default interior handle sleeve nut fit?
1931 Murray fordor. I am wondering about the fit of the sleeve nut for the interior door handle. When I finished installing one it sat proud of the handle i s this correct? It does not look right to me I think flush or slightly inside the handle would look better. Original handles the sleeve nuts are new
Thanks
linkpin is offline   Reply With Quote
Old 08-20-2019, 08:42 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: interior handle sleeve nut fit?
There might be a lock washer stuck inside the pocket of the handle.
If not, then I'd trim the inner edge for a flush fit.
Old 08-20-2019, 10:03 PM   #3
J Franklin
J Franklin's Avatar
Post a photo, I think they are above the handle on mine. Maybe yours are correct. Are they or the handles reproduction?
Old 08-21-2019, 08:32 PM   #4
linkpin
[QUOTE=Tom Wesenberg;1790202]There might be a lock washer stuck inside the pocket of the handle.
If not, then I'd trim the inner edge for a flush fit.[/QUOT
I tried with and without a lock washer and the nut is proud of the handle either way
Thanks
Old 08-21-2019, 08:34 PM   #5
linkpin
The Nuts are new handles are original. I will take a picture tomorrow
Thanks
Old 08-22-2019, 06:14 PM   #6
linkpin
Old 08-22-2019, 06:20 PM   #7
linkpin
If someone can measure the length of a original nut I would appreciate it.
Old 08-22-2019, 06:41 PM   #8
J Franklin
J Franklin's Avatar
If you put the backside on a belt sander for a few minutes it will sit lower. It does look tall or your handle does not have enough depth. the handle could be a replacement. Maybe someone has an original apart for comparison. The original drawings can be found in Detroit I believe.
Old 08-22-2019, 06:55 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
I don't know if this helps you or not. I just ran out and took a picture of my door handle. I believe they are both Repos (handle and nut). This is without the lock washer.
To tell the truth, I never paid much attention to them. Hopefully someone has an original we can look at.
Old 08-23-2019, 08:32 PM   #10
linkpin
Thanks for the picture
