09-18-2012, 07:51 AM | #1 |
Embarassing momments
The recent post by Rubatoguy "Is there a trick to getting a head on" to which he admitted to an embarassing obvious oversight on his part got me thinking, how many of us have done something rather embarassing while restoring or servicing our beloved Model A's.
I'll be the first, so here goes: On completeing a rebuild of my Differential (Rear Axle) I was in the process of assembly and just as I was about to insert the axles and diff centre to the diff halves (trumpets) when my wife called me to lunch. After lunch I went out to finish the job. Without thinking I picked up the axle assembly and turned them around thus placing the crown wheel on the wrong side of the rear axle. The result was of course that I finished up having 1 forward gear and 3 reverse gears. What a shock when I went to drive out of my workshop and nearly drove thru the back wall instead. Believe me, once you make this mistake you will never do it again.
Adjust your points with gentle blows of a 2 pound hammer Last edited by RUNNERBUN; 09-20-2012 at 12:54 AM. |
