Old 07-24-2024, 06:06 PM   #1
fourfords
fourfords's Avatar
Default Model A Fan
I have an original late '31 two blade fan. Looks like Ford knew of this breaking issue prior to the end of Model A production, modifying the construction to alleviate the breaking problem. Question is: Is this modification enough to trust installing?
fourfords is offline   Reply With Quote
Old 07-24-2024, 06:18 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Model A Fan
I think you should ask yourself "Do I trust this old relic (Known to be dangerous) with my life?" If Ford changed the way they made fans before the end of production, it would only have been with the intention making it last a few years, not the 90 or so that have now lapsed.
I bet that even if it is an "improved" fan, rust has been eating away at it for too long IMO.
The short answer as far as I'm concerned is NO!
I sometimes wonder what happened to the people who asked me for directions.
Old 07-24-2024, 11:18 PM   #3
spdway1
spdway1's Avatar
By the way, this is a cool post.
spdway1 is offline   Reply With Quote
Old 07-25-2024, 10:47 AM   #4
Fullraceflathead
Fullraceflathead's Avatar
Can you post pictures of the improved fan I'm curious as I've never seen 1 other than the earlier ones.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 07-25-2024, 11:04 AM   #5
nkaminar
nkaminar's Avatar
I am a real Model A Fan. Have been since I was a teen.
Old 07-25-2024, 03:07 PM   #6
fourfords
fourfords's Avatar
Don't have a picture as of yet. I'll try to describe: The center hub is identical to the common Model A Fan. On the back side of the two blades, the double sheeted area stops about 2 inches from the hub with a weld, then continues on with one sheet metal piece, thereby eliminating moisture and rust from the inside. ( I'm sure you've seen original Model A fans with swollen blades). Also, alleviating some stress to the blades by cutting each blade's weight in half. So its overall, a somewhat lighter fan.
Old 07-25-2024, 03:30 PM   #7
J Franklin
J Franklin's Avatar
Run with a new fan, and show with the original one.
Old 07-25-2024, 11:26 PM   #8
Manuel
I would love to see a close up pic.
Manuel is offline   Reply With Quote
Old 07-26-2024, 05:16 AM   #9
updraught
updraught's Avatar
Are you an early one without any improvements?
updraught is offline   Reply With Quote
Old 07-26-2024, 02:29 PM   #10
rotorwrench
rotorwrench's Avatar
Volume 6 of the MAFCA Restorer series of books has a pattern for a hub area reinforcement patch that can be welded on to reinforce the area where the most common failure point is. The fans weren't made from very thick steel stampings so they crack and eventually fail. I don't think Ford engineers would have ever thought that so many model As would still be around after 90+ years.
Old 07-26-2024, 02:39 PM   #11
nkaminar
nkaminar's Avatar
Updraught, I am afraid I have only gotten older and starting to fall apart.
Old 07-26-2024, 03:23 PM   #12
Chris Haynes
Chris Haynes's Avatar
I bought a Carbon Fiber Two Blade Fan from a guy in New Zealand.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-26-2024, 07:56 PM   #13
JayJay
Probably not a whole lot of unbroken late ‘31 fans around that would be reliable for daily driving. I’m a relatively unbroken ‘53 fan, but still consider myself fairly reliable. Hope that lasts for a while.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 07-26-2024, 09:48 PM   #14
Bleedblue4life
Bleedblue4life's Avatar
My friend has a broken late 31 fan that went through a hood on his wall.
Bleedblue4life is offline   Reply With Quote
Old 07-27-2024, 07:22 AM   #15
oldspert
oldspert's Avatar
Me too, I bought my first one when I was 15. A 1929 Coupe.
oldspert is offline   Reply With Quote
Thread Tools
Display Modes
