Old 05-12-2021, 09:33 AM   #1
Ed in Maine
Default 31 Model A Backfires on Shutdown
What makes a Model A backfire when you turn the key off? Car seems to run OK otherwise. Ed
Ed in Maine is offline   Reply With Quote
Old 05-12-2021, 12:38 PM   #2
nkaminar
nkaminar's Avatar
Default Re: 31 Model A Backfires on Shutdown
Unburnt fuel/air igniting in the hot exhaust manifold, exhaust pipe? There are couple things to try: Let it idle to for a while before turning it off or turn off the fuel and let the carburetor run dry before shutting it off. You can also try pulling the choke to kill the engine then turn it off. Another thing to do, which Model T guys do, is to set the idle so low that the engine dies when the throttle is shut then use the hand throttle to set the idle up enough so that it does not stall when using the car. The advantage with this option is that when descending a hill you can turn the idle down to the point where no fuel/air in getting into the engine.
If it is backfiring through the carburetor then that is a different story and probably due to a leaky intake valve.
Old 05-12-2021, 03:22 PM   #3
dj
always make sure you retard the spark before shutting down
DEnnis
dj is offline   Reply With Quote
Old 05-13-2021, 10:55 AM   #4
700rpm
700rpm's Avatar
Dennis, Where did you hear that? I have never heard that advice, nor have I ever done that, and have had no adverse effects in over 50 years of driving Model A’s.
Ray Horton, Portland, OR
Old 05-13-2021, 11:46 AM   #5
McMimmcs
McMimmcs's Avatar
[QUOTE=700rpm;2016152]Where did you hear that? I have never heard that advice, nor have I ever done that, and have had no adverse effects in over 50 years of driving Model A’s.[/QUOTE]
X2
McMimmcs is offline   Reply With Quote
Old 05-13-2021, 01:34 PM   #6
dj
when you start the car you retard the spark and when you shut it down
Starts better and has a better chance of not back firing , it slows the engine ideal down
so it shuts down quicker .
learned it from the mafca teck director years ago. not saying you have to but good idea.
Dennis
