Old 08-19-2016, 03:58 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default Locking Pins
Working on front end and wondering if the locking pin drives in flush ? Red book says to hammer in then tighten nut looks like I have about 1/8" sticking out . Should I tighten a little and try a bigger hammer ?
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 08-19-2016, 04:18 PM   #2
700rpm
700rpm's Avatar
Default Re: Locking Pins
Yours looks just about like mine on all my A's, not flush.
Ray Horton, Portland, OR
Old 08-19-2016, 04:21 PM   #3
Jim/GA
Jim/GA's Avatar
Thumbs up Re: Locking Pins
My brother's favorite tool: a bigger hammer!
As mentioned, yours look about right.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-19-2016, 04:40 PM   #4
C26Pinelake
Jim. You say you support all aspects of the hobby. Does that include turning an A into a hot rod ? Wayne
C26Pinelake is offline   Reply With Quote
Old 08-19-2016, 06:15 PM   #5
Synchro909
Synchro909's Avatar
I've just gone through this when I found the king pin was loose in the eye of the axle. On Monday, I'm going t a friend's workshop and we will close the eye again. The COTTER PIN should look like your pictures show. All of my As are like that. I find a good way to make sure they are tight is to hold pressure on the nut with a ring spanner while I hit the head of the cotter pin with a hammer. With each blow, the spanner will turn a little more. Stop before you stretch the cotter pin.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 08-19-2016, 10:00 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I assume you mean locking pin, not cotter pin.
If your locking pin goes in with the head flush, then I would say you have a bad axle. I fought this for two years before I gave up and found a good axle.
Old 08-20-2016, 01:35 AM   #7
Synchro909
Synchro909's Avatar
No, I mean COTTER PIN, not a split pin. This is another term that has been corrupted over time in the US
Old 08-20-2016, 02:10 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Yours look fine. How far it goes in is a function of the wear of the parts.
Old 08-20-2016, 03:44 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
What's the difference?
Here's pictures of what I call hair pins and cotter pins.
Old 08-20-2016, 04:14 AM   #10
Synchro909
Synchro909's Avatar
The picture posted my Mike (post #7) is a cotter pin. hey are also used in places like attaching the pedals to the shaft through the centre bracket of a bicycle.
Old 08-20-2016, 04:35 AM   #11
Mike V. Florida
Clip-hairpin Cotter Stainless Steel
Old 08-20-2016, 07:29 AM   #12
tbirdtbird
the pic in #7 would never be termed a cotter pin in the USA
'31 180A
tbirdtbird is offline   Reply With Quote
Old 08-20-2016, 12:31 PM   #13
Glenn C.
Glenn C.'s Avatar
The pic sent in by Mike as showing a "Spindle Pin Locking Pin" is correct as per the original Ford parts book of 1931. Part #A-3122C
Glenn C. is offline   Reply With Quote
Old 08-20-2016, 01:39 PM   #14
100IH
HERE HERE, due to the world wide nature of the Model A. the original parts book should be the last word for differing terms that confuse so many threads and discussions. Dennis Pereria did begin with the correct term. Well meaning barners twisted the issue to get all the juice out as frequently happens.
100IH is offline   Reply With Quote
Old 08-20-2016, 05:37 PM   #15
700rpm
700rpm's Avatar
"What we have here is a failure to communicate." -Cool Hand Luke
Old 08-20-2016, 06:56 PM   #16
Synchro909
Synchro909's Avatar
I have noted that. I'm not sure whether in the US, it was ever called a cotter pin but it seems to me that something has gone awry over there and the names have changed. Now, just to throw a little more fuel on the fire (not gas because you can't throw a gas), I ask "Where does a ring gear go?" Answer: On the flywheel.
Old 08-20-2016, 07:17 PM   #17
Dennis Pereira
I'm not sure if the issue is solved on the proper name of the locking pin but with a mix of factory and after market parts she's going back together better than she came apart .
Dennis in Kelsey ca
Old 08-20-2016, 07:38 PM   #18
Synchro909
Synchro909's Avatar
That's what it's all about. May I suggest you get those pins (call them tapered lock pins or cotter pins - who cares) tight by applying pressure with a ring spanner on the nuts while giving the other end of the pin a whack with a hammer. You'll be surprised how far the spanner turns with each blow. Don't get too enthusiastic, though.
Old 08-20-2016, 08:14 PM   #19
Dennis Pereira
There's a little black paint on the old pins that marks the depth the old pins were set maybe 1/16" more . I think a box wrench is the same as a ring spanner ? but I have the big hammer part down pat .
Dennis in Kelsey ca
Old 08-20-2016, 08:59 PM   #20
Jim/GA
Jim/GA's Avatar
Yes, a ring spanner is the same as a box wrench in America.
And a big hammer is, well... a big hammer!
Jim Cannon
