02-08-2015, 08:08 PM | #1 |
Carburetor problems
I've been having carb problems lately, typically I run a Tillotson because it worked great. However, a few weeks back I started having idling problems--as in it doesn't idle. It dies if you don't have the idle fast using the column lever. The carb is clean in and out, I pulled it apart again today and cleaned it with spray carb cleaner blowing through all the passages. It still has the same problem of not idling. It ran perfectly before... Ideas?
The second carb problem is my backup carb. The backup is a side bowl late 31 Zenith. It was rebuilt, but when you turn the gas on it just pours out the back. The float seems adjusted right based on my measurements and remeasurements. Could the needle/seat assembly just be "bad". Other thoughts or suggestions? Thanks!
Experience is a cruel teacher. It gives the exam first, then the lesson. |
02-08-2015, 08:14 PM | #2 |
Re: Carburetor problems
ck for a vacuum leak at the intake
02-08-2015, 08:31 PM | #3 |
"it just pours out the back."
you answered your own question.
'31 180A |
02-08-2015, 08:32 PM | #4 |
02-08-2015, 08:36 PM | #5 |
LOL it was a 2-question final exam.
You took part A and I grabbed Part B
'31 180A |
02-08-2015, 08:56 PM | #6 |
02-13-2015, 10:47 PM | #7 |
I think we can rule out an intake leak. I replaced the gaskets, checked the recently milled intake/exhaust alignment which is dead on, checked for a leak at the wiper/line, and looked for cracks. Unfortunately, it still dies when idling down.
