Old 10-13-2014, 11:11 PM   #1
31 Woody
31 Woody's Avatar
Default Speedometer is off
On our station wagon, I downloaded an app for my cell phone to check the speedometer. As I suspected, it read fast. With a speedometer reading of 75. The app said 56, which is clearly based on GPS data and reliable. Later in the day I came upon a stationary speed awareness sign that again pointed out my speedometer was reading fast.
My Dad rebuilt it several years ago, but that is about all that has changed. Any thoughts on correction?
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 10-13-2014, 11:39 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Speedometer is off
How's the odometer? If it is incorrect, then the speedo gear might also be incorrect.
Depending on the manufacturer it can be adjusted if the odometer is reading good.
http://www.modelahouse.com/tech/spee...r/fischer.html from Bob Johnsons' site.
Old 10-14-2014, 12:44 AM   #3
pooch
pooch's Avatar
Just leave it be and brag that your A goes 75 MPH easy .
pooch is offline   Reply With Quote
Old 10-14-2014, 07:45 AM   #4
31 Woody
31 Woody's Avatar
I think the odometer reads incorrectly too, but I have to check that to be sure.
Old 10-14-2014, 08:25 AM   #5
Patrick L.
Patrick L.'s Avatar
I'm of no help. Mine is just the opposite. At 40 mine reads 45 and at 50 its saying 57.
As long as I know I'm not worried about it.
Old 10-14-2014, 08:44 AM   #6
C26Pinelake
Remove it and send it to a professional who will calibrate it properly.
Wayne
C26Pinelake is offline   Reply With Quote
Old 10-14-2014, 10:21 AM   #7
Charlie Stephens
Wayne
Check the odometer before you send it to someone to calibrate. If the odometer is off the "calibration" may consist of getting the correct gear to attach to the torque tube.
Charlie Stephens
