Old 01-03-2021, 12:46 PM   #1
flathead 53
Default headlights dim/ 53 f-100
my headlights are very dim ,on my 53 f-100, 6 volt, truck has all new wiring , getting 6 volts at battery , rear tail lights are bright , grounds are good , getting 4 volts at head light sockets, not sure what to try next.
flathead 53 is offline   Reply With Quote
Old 01-03-2021, 01:22 PM   #2
marko39
Default Re: headlights dim/ 53 f-100
Check voltage in and out of your switch, should narrow it down.
marko39 is offline   Reply With Quote
Old 01-03-2021, 01:35 PM   #3
alanwoodieman
corroded connections. clean your ground wire connections anyway, I had trouble with grounds in a 52 and finally ran a ground wire directly to the frame, problem solved
Old 01-03-2021, 05:06 PM   #4
supereal
supereal's Avatar
That is why I use 2 relays (high & dim) to operate my headlights. By the time the power goes through the dash switch, the dimmer switch, and a handful of the "bullet" connectors, the resulting voltage is inadequate, thus the 4 volts you mentioned. Now my headlights are as bright as new. It doesn't take much resistance to soak up voltage In Ohm's Law E=IR. Thus E (voltage) is the product of I (amperage) and resistance (R). My unit is mounted at the left front under the hood where the main headlight junction is located. The relays are operated by the original circuit, and provide full battery power to the headlights so after dark driving is safe.
supereal is offline   Reply With Quote
Old 01-03-2021, 11:35 PM   #5
koates
Yes need to find a 6 VOLT twin headlight relay to feed both high and low beam headlights. Very important to supply a heavy gauge power supply from the battery side of the starter solenoid to the relay battery terminal. The relay outputs will then feed the lights directly with next to no voltage drop. Regards, Kevin.
koates is offline   Reply With Quote
Old 01-04-2021, 06:42 AM   #6
big job
big job's Avatar
As Koates wrote; there are many relays on ebay. with reasonable prices. The one you
need has 5 terminals #1 terminal power 'heavy gauge wire' next terminal low beam
in next terminal low beam out next high beam in and high beam out this relay is the
best one. I wouldn't call this a band aid cause many vehicles had these from the factory.
sam
big job is offline   Reply With Quote
Old 01-04-2021, 03:12 PM   #7
JayChicago
JayChicago's Avatar
Possible/maybe simple fix:
Could be corrosion on the seldom-used dimmer switch's internal contacts. Step on the dimmer switch a couple dozen times to clean the contacts.
Old 01-04-2021, 03:32 PM   #8
Aarongriffey
All good advice posted above.
Here’s what I have hound several times, including on my F1.
Turn the lights on, wait a full minute and cautiously touch the headlight switch under the dash where all the wires connect to the light switch.
If it is too hot to touch you’ve found the problem.
Most light switches will get warm but not too hot to touch.
If you can not find a replacement switch that you are satisfied with then it’s relay time.
Make sure the wire to dimmer switch and the wires to headlights are at least size 14.
Aarongriffey is offline   Reply With Quote
Old 01-04-2021, 04:42 PM   #9
supereal
supereal's Avatar
For relays, I use 6 volt starter solenoids. They are heavy duty and less expensive than a comparable relay, even if you can find one with a 6 volt coil. We buy them at a local NAPA store. Our other uses include the top control for my convertible top.
Old 01-04-2021, 05:30 PM   #10
meric42
meric42's Avatar
I agree with the above and have bought NOS period correct relays through eBay but if you are not to worried about the look I have also used these with good success.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Combined with 6 Volt quartz halogen bulbs my lights a as good as or better than a lot of more modern cars.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 01-04-2021, 06:51 PM   #11
flathead 53
I have six volts going to the head light harness right were they connect to the head light wires to crossover wiring , but checking voltage at the headlight plug I get 4 volts, the problem must be some where ,in the cross over wiring
Old 01-04-2021, 10:03 PM   #12
JayChicago
JayChicago's Avatar
Good info! That's the proper way to diagnose an electrical problem: test so you can narrow-down and isolate the problem to one area.
I'm not familiar with the '34 headlight loom so can only suggest general trouble shooting ideas. Continue with your voltmeter until you can isolate further. (meter ground lead to a good ground) Do you get the 4 volts at both headlights? If you wire brush and use contact cleaner on every connector and then test the voltage after each cleaning, you may find the problem.
Old 01-04-2021, 10:27 PM   #13
JSeery
JSeery's Avatar
I put this together a while back if anyone is interested.
Old 01-05-2021, 07:15 PM   #14
flathead 53
checked all connections ,and grounds , all good . checked head light sockets with power on ,both sides 6 volts , installed one seal beam on driver side ,now checked pass side socket reads 4 volts, with no lights installed reads 6 volts at both sockets. what could it be?
Old 01-05-2021, 11:48 PM   #15
aussie merc
aussie merc's Avatar
check the harness there must be a 'Y' junction in there somewhere [left/right join] you will probably find its corroded or worse still someone has stabbed the harness leaving a hole in the insolation waters got in and caused localized corrosion to the wire [can be a bugger to find so look for a bulge , soft spot, any change in the shape of the wire ]
aussie merc is offline   Reply With Quote
Old 01-06-2021, 06:59 AM   #16
Steves46
Steves46's Avatar
This was the problem I had when I first got my 55 F100-cleaned the wire connections (which are exposed to the elements) and had nice bright headlights.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 01-09-2021, 09:50 PM   #17
Bluedot
WD-40, used conservatively, is great for cleaning contacts (and about a million and a half other uses)
Bluedot is offline   Reply With Quote
Old 01-10-2021, 02:54 PM   #18
corvette8n
corvette8n's Avatar
Got a set of contact cleaning brushes from NAPA, used them a lot when I had my Corvette, not sure why but most of my connections on that car were very corroded, some so bad I had to splice in ground wires on each side of the connector. Use something like this to clean your sockets.
File Type: jpg ED460E92-71C6-4347-B24F-3750BF4B22EB.jpg (21.7 KB, 3 views)
