10-29-2015, 08:58 PM | #1 |
Ford 6 cyl air cleaner
I have this air cleaner from a Ford, I believe it is a 6 cylinder because it mounts on the side, dry element. Does anyone know what years and engines this fits?
10-29-2015, 09:22 PM | #2 |
Re: Ford 6 cyl air cleaner
I am no expert, but I suspect that it is for a 52-53 Mercury or possibly an early to mid 50's Lincoln. I know that the carb's on those used a carb. like the one on my '51 Merc. although my '51 is an oil bath, the air intake is out the back instead of the top like a normal carb. and the mounting clamp for the carb. to air cleaner is the same style as the one in the picture. it is only a guess on my part, I could be completely wrong.
10-29-2015, 11:48 PM | #3 |
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
10-30-2015, 12:08 AM | #4 |
looks like I am wrong and you are correct Lanny, was jut a guess on my part,
10-30-2015, 09:19 AM | #5 |
My grampa had a new 57 four door with a 223, it had that filter.
10-30-2015, 11:43 AM | #6 |
11-04-2015, 07:53 AM | #7 |
Thanks everyone for the help, the 223 cu in looks like what it is.
11-04-2015, 08:43 AM | #8 |
engine sat to high so they had to go with that.
11-04-2015, 08:03 PM | #9 |
This is what the Air Cleaner looks like on a 1942 Ford with the GA Six Cylinder Engine. |
11-05-2015, 09:16 AM | #10 |
Here's my setup.
