12-06-2021, 12:22 AM | #1 |
Late 1932 Driveshaft Length
Hi,
I need to build a driveshaft for a late 1932 rear (the scalloped one that is the same as 1933-34). I have the original torque tube. Does anyone have one they could measure? If not, is the driveshaft 1.6” shorter than the torque tube for outside to outside? I have done a bunch of searching and there are several different lengths quoted. I have a 1934 driveshaft to shorten, the transmission end is badly damaged on the bearing surface. I picked up a 1936 end, it is larger at the tube end. Has anyone turned one down to fit? What other years would be better to use? Is the early 1932 the same driveshaft size, but different on the pinion end? Thanks |
12-06-2021, 01:10 AM | #2 |
Re: Late 1932 Driveshaft Length
Hi; Need to do a search here- this topic has had many threads posted on it; There are two different lengths for 33/34 torque tubes and the '32 is even by it's self. Newc
12-06-2021, 01:27 AM | #3 |
Duke .....Here's what I have posted many moons ago, and nobody has spoken-up to the contrary....YET! DD TORQUE TUBES '33/'34 V8 = 61-13/16" 4-cyl = 60-3/16" DRIVE SHAFTS '33/'34 V8 = 60-5/32" 4-cyl = 58-7/16" __________________________________ 1932 SCALLOPED Torque Tube and Drive Shaft '32 Torque Tube = 53-5/16" '32 Drive Shaft (Matching) = 51-5/8" ___________________________________ |
12-06-2021, 02:48 AM | #4 |
How to tell a 1932 Ford Differential? Where the Radius Rods join the Axle Housings, the Flanges are straight, and not angled as they are on 1933 and 1934 Ford Differentials. |
12-06-2021, 09:49 AM | #5 |
Late '32 rear axle housings use straight radius rods like the '33-'34 axles.
12-06-2021, 11:06 AM | #6 |
12-06-2021, 11:10 AM | #7 |
This is a late 1932. The other picture is an early. Hope to help someone else trying to figure this out.
12-07-2021, 02:53 AM | #8 |
Late 1932 Ford Rear End - with Straight Radius Rods - Photo by Duke |
12-07-2021, 03:42 AM | #9 |
I believe the photo above is a 33/34.
32: Brackets straight, rods are bent. 33/34: Brackets angled, rods are straight. Mart. |
12-07-2021, 03:51 AM | #10 |
Early Ford Differential showing Straight Radius Rod Mounts. |
12-07-2021, 09:03 AM | #11 |
Mart,
Actually there are two versions of the late '32 straddle-mounted pinion gear rear axle assembly. The first version (rarely encountered) had dog-leg radius rod ends like the earlier '32 axles and the second version had the straight radius rods like a '33-'34 axle. |
12-07-2021, 11:42 AM | #12 |
Yes, the picture I posted is a late 32 rear axle. Unfortunately it has no driveshaft. David, do you know anything about the length? I am a little unsure as someone measured one for me and it was as long as the torque tube. He was not positive that it came out of the tube as he bought it disassembled.
Thanks |
12-07-2021, 12:11 PM | #13 |
Sorry, but I am away from my old car stuff at present and I do not want to rely on my memory. One aspect of the question that can cause there to be different answers is what part or whole of the shaft was measured.
For example, the original engineering drawing for the late '32 axle cites a 52.318" length for the drive shaft and 54.89" for the torque tube, both of which are not the same as those cited in V8COOPMAN's post above. I did not make note of what the drawing dimensions used for the measurement points and until I do that I cannot reconcile the differences. |
12-07-2021, 12:17 PM | #14 |
I did a video on this and had some magic numbers.
From my investigations from factory ford parts the driveshaft is 45mm shorter than the torque tube. If you have the torque tube you can deduce the length of the driveshaft. 45mm = 1.771" Nearest fractional size is 1-49/64" I found using mm for this job was far easier than inches. FWIW here's a link to the video. https://youtu.be/-mOo2eZX_2U Mart. Last edited by Mart; 12-07-2021 at 12:29 PM. |
12-07-2021, 12:29 PM | #15 |
V8Coopman has it pretty close. When a buddy shortened his 34V8 torque tube and driveshaft for his '32 He made it 8 9'16 " shorter .
12-07-2021, 03:02 PM | #16 |
I have both the driveshaft and torque tube out and coop's measurement is correct.
12-07-2021, 04:59 PM | #17 |
Thank you everyone, Deuce5wndw, is the measurement end to end or end to pin hole?
Thank you! |
12-07-2021, 05:19 PM | #18 | |
12-08-2021, 10:31 AM | #19 |
Measured end to end. Uncut original 32.
12-08-2021, 10:39 AM | #20 |
Thank you deuce, could you show the measurement from the pinion end to the pin hole? Thank you!
