Old 08-11-2021, 02:02 PM   #1
packrat6
Default engine compression
what should the compression read on a warm engine ('30 four cyl.) versus a cold engine?
packrat6 is offline   Reply With Quote
Old 08-11-2021, 04:09 PM   #2
Werner
Werner's Avatar
Default Re: engine compression
Hi,
on my not tuned engine I measured:
Cold: 4.9, 5.2, 5.2, 5.2 .
Hot: 5.2, 5.2, 5.2, 5.2 .
(kp/cm²)
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 08-11-2021, 04:23 PM   #3
Gene F
Gene F's Avatar
On mine I checked it Sunday and the readings were 79, 80, 80, 80 LBS. Wonder what that works out to?
Gene F is offline   Reply With Quote
Old 08-11-2021, 05:20 PM   #4
Anteek29
Anteek29's Avatar
Compression numbers will depend on the type of head installed...stock or other.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 08-11-2021, 06:41 PM   #5
packrat6
i'm a bit confused......book says 75 or so....mine is reading 100-110 cold and 100-106 warm. so...whats up with that? the engine was rebuilt prior to my getting the car but i have no information on details.
Old 08-11-2021, 06:56 PM   #6
Big hammer
It has a high compression head on it, or your testing under sea level !
get a bigger hammer tap done
Old 08-11-2021, 07:03 PM   #7
nkaminar
nkaminar's Avatar
5.2 is in bars, I think, which is one atmosphere or 14.7 psi. So converting to psi yields 76 psi. 80 LBS is 80 psi, or pounds per square inch. 80 psi is equal to 76 psi within measurement error bands.
Old 08-12-2021, 05:15 AM   #8
Patrick L.
Patrick L.'s Avatar
Mine is 45# across the board, been that way since 1975 when I bought it. It was rebuilt in 1961.
Old 08-12-2021, 08:27 AM   #9
old31
For a good approximate way to get what your number should be, number do this.
14.7x the head ratio number.
Example: 14.7 x 6.1=89.67 psi or 14.7x 4.2=61.74psi.
Old 08-12-2021, 10:34 AM   #10
burner31
burner31's Avatar
I have a 6:1head with the modern gasket, reading 95 psi in all tubes
This is after lapping valves, honing cylinders, new rings and pistons, also installed the adjustable lifters, did this about three months ago, no changes or issues so far
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 08-12-2021, 11:08 AM   #11
CatMan1
Some of these look quite high! Mine was supposedly rebuilt about 1,000 miles ago, is all stock, and is reading..... #1 60, #2 55, #3 55, #4 60. That is PSI. Should it be higher?
CatMan1 is offline   Reply With Quote
Old 08-12-2021, 12:20 PM   #12
Anteek29
Anteek29's Avatar
Looks like your numbers are right on the money - with a stock 4.2 head
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 08-12-2021, 12:22 PM   #13
CatMan1
Thanks! That's a relief!
Old 08-13-2021, 07:54 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
To estimate the compression ratio from gauge readings, divide the gauge reading by the atmospheric pressure in your region. At sea level, Atmospheric Pressure = 14.7 psi. In Denver, Colorado Atmospheric Pressure is 12 psi:
79/14.7 = 5.4:1
55/14.7 = 3.7:1
62/14.7 = 4.22:1
Engine power & torque vary with compression. Theoretically, gauge readings below 62 psig at sea level (stock 4.22:1 Ratio) are indicative of less than 40 hp and less than 128 ft-lbs of torque. How much less requires power & torque requires dynamometer testing.
Bob Bidonde
Old 08-13-2021, 09:00 AM   #15
Patrick L.
Patrick L.'s Avatar
Compression is a good thing to know, for now and for the future issues.
But, as long as the engine operates as it should, who cares. Run it and enjoy it.
Thread Tools
Display Modes
