06-09-2020, 04:09 PM | #1 |
Brake fluid gone..
Got the 36 out today and no brake pedal..No fluid in master cylender and no sign of leakage so ??? When built i used silicone fluid as everyone told me that is best so wonder if it evaaporated..
06-09-2020, 04:17 PM | #2 |
Re: Brake fluid gone..
It had to leak out somewhere. It doesn't evaporate.
06-09-2020, 04:20 PM | #3 | |
Pull the drums and you'll likely find the leak(s). It sure didn't evaporate.
06-09-2020, 06:11 PM | #4 |
Wait is it april 1 , 36 were mechanical. Okay not a joke . , since you converted it did you also add a power booster ? If not my idea is out the window aka not valid
06-09-2020, 06:40 PM | #5 |
I wouldn't use Silicone brake fluid on my wheelbarrow....even if it did have brakes. DD
06-09-2020, 06:42 PM | #6 |
06-09-2020, 07:08 PM | #7 |
06-09-2020, 07:30 PM | #8 |
Once I had it in my '68 Corvette (when I did a complete brake rebuild), it was fine. Getting it in and bled was such a pain in the ass that Ill never use it again. It's just not worth the effort.
There has to be a reason that no (none that I know of anyway) automobile manufacturers use it OEM. |
06-09-2020, 07:54 PM | #9 |
A couple reasons new car manufacturers Don't use dot 5 is that it would be
way more costly to put in ALL the new cars made, compared to dot 3 or 4. The second reason is dot 5 don't work well with the super fast pumping action of the anti-lock brake systems. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
06-09-2020, 08:02 PM | #10 | |
That's a "no-brainer"! This way, Mr Goodwrench et al can "urge" you to bring the vehicle in every two years for a recommended fluid R&R. Maybe I've been lucky, but I've never been a big advocate of changing brake fluid. One more thing.....our STOCK '37 Ford coupe has never, ever leaked one drop of brake fluid. DD |
06-09-2020, 08:38 PM | #11 |
Ok looks like i have to pull hubs so as i dont have the pullsr for the rear ones ill try front first and cross my fingers lol
06-10-2020, 06:37 AM | #12 | |
Ken |
06-10-2020, 06:41 AM | #13 |
I like the dot 5 because it is not corrosive to paint. It also is not hydroscopic. I've hed it in my 49 for 45,000 miles and while I do need to add it periodically I do not have the other problems.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
06-10-2020, 07:59 AM | #14 |
“.our STOCK '37 Ford coupe has never, ever leaked one drop of brake fluid. DD“
Are we back to the April Fools thing again????....... Mark
06-10-2020, 10:07 AM | #15 | |
Well, you're right....it is June already. But I ain't lyin'....that sucker don't leak for squat! DD |
06-10-2020, 10:22 AM | #16 | |
Sure, age can effect rubber pieces but again, properly built... no leaks.
06-10-2020, 12:19 PM | #17 |
Neither my modeA, or 36 will leak brake fluid, I used to have a 39,and a 46, got rid of them because of brake failures, leaks, pulling, grabbing brakes---
If you buy new wheel cylinders take them apart first to see if properly made-- holes drilled to top for bleeder, at center for fill, --- if re sleeved take them apart to inspect/clean out the chips from the machining process Proper restoration to original specifications will eliminate brake fluid leaks and ensure reliable brakes |
06-10-2020, 02:07 PM | #18 |
in the master cyl there is a check valve it,s purpose is to keep low pressure in the system. if the car sits for a long period of time it bleeds off .the wheel cyls relax & leak no car was built to sit for long periods of time. there is three things you can do to reduce this from happeing one way is install an after market check valve. second way is every week or two step on the brake pedal. third is drive the car . cars were meant to be driven i have seen a lot of traled show cars that are dry. no brake fluid no eng coolent empty battery empty fuel system drive your car thats what it was made for
