10-28-2019, 09:08 PM | #1 |
What do I need to do to get a reliable engine?
Aquired my '30 Tudor about 3 years ago. Drove it mostly around town every weekend. One day, sitting at a light something came apart on the crank...still haven't pulled that pan but there are big parts rolling around in the bottom of the pan.
Bought a 2nd engine from a guy locally about 3 months ago for $1,000. Ran good, but lots of blowby and a significant oil leak at the rear of the engine. Decided to go for a 90 mile drive last weekend, only made it about 25 miles. The first 15-20 or so were around town...then on a two-lane highway at about 50mph the "new" engine let go. Knocking at certain RPM and a significant vibration. 90% of my driving is around town, but I'd like to be able to do the occasional 100 mile trip at 50mph or so without leaving engine guts behind me. What do I need to do to get a reliable engine that will go at least 50,000 miles? That'd last me many years. It seems that people have trouble putting together a reliable "A" engine, or at least a few hobbyists do. I think I want bearing inserts. Pressure oiling seems nice too. What else should I look for in a shop-built "A" engine? Are there any reputable shops near DFW, TX that build "A" engines? |
10-28-2019, 09:33 PM | #2 |
Re: What do I need to do to get a reliable engine?
Need some help with this, Grace and Faith are bugging me to go driving!
2019-05-30 20.32.25 by Steve Ruse, on Flickr 2019-05-30 20.24.54 by Steve Ruse, on Flickr 2019-08-17 13.57.03 by Steve Ruse, on Flickr 2019-08-18 15.33.10 by Steve Ruse, on Flickr |
10-28-2019, 10:15 PM | #3 |
10-28-2019, 10:17 PM | #4 |
A model a engine built back to factory standards and tolerances will last a lot of miles. I think careful machining layout and precise balancing will make your engine last the way you want to use it. I think you should look into a Mitchell Overdrive to maintain higher speeds.
10-28-2019, 10:21 PM | #5 |
How much do you want to spend?
Stock engine engine with inserts oil filter partial or full flow different cam counterbalanced crank lightened flywheel v8 clutch center main pressurized all mains pressurized connecting rods pressurized point ignition electronic ignition How about the rear end, different gears overdrive? and so on, and so on, and so on.
10-28-2019, 11:04 PM | #6 |
http://www.modelaparts.net/ Last edited by DJ S; 10-28-2019 at 11:11 PM. Reason: Added Link |
10-28-2019, 11:07 PM | #7 |
Call Steve at Berts. Good People to work with.
Good Luck. |
10-29-2019, 12:40 AM | #8 | |
10-29-2019, 07:29 AM | #9 |
Looks to me like you need to hire a couple of mechanics that have a few more years experience! LOL
Cute Kids!! |
10-29-2019, 11:31 AM | #10 | |
First of all, don't pay $1,000 for a $100 engine. At least, you now have two to choose from to rebuild one. Just don't be like the clueless guy on that Hagerty Youtube video! That video is a good tutorial on what not to do, for the most part. Talk to owners who drive their A's on tours about the modifications one to their engines. |
10-29-2019, 11:58 AM | #11 |
The main thing is to have somebody that knows what they are doing and is not a jerk. Also an important thing is that everything is balanced. It will always vibrate if things are out of whack. If you want to go 50, put a high compression head on.
"The more things change, the more they stay the same." |
10-29-2019, 04:33 PM | #12 |
Good afternoon...One suggestion is to check with the two national Model A clubs and see if there is a local club near you. The local clubs always know who the best engine builders are...there are also several on this site who answer questions now and again...Enjoy...Ernie in Arizona
10-29-2019, 07:07 PM | #13 |
I build Model A and B engines up in MINNESOTA but I know some of the good builders across the US. As mentioned in an earlier post, Ron Kelly builds a very good engine and he is near you. Ron will advise you as to what you need after you explain how fast and how far you want to go. A bit of advice; Careful work and good parts command a good price. Buy a good one and then enjoy it for years.
Good Day! |
10-29-2019, 07:33 PM | #14 |
What you need for an engine to be reliable is 'Good foundations'.
So basically a crankshaft that is nicely ground & polished. A camshaft that doesn't have missing lobes ect. And a clean oil pan. In stock form they're a tough engine. If you want pressure oiling, i can't help you there, but as long as it's done well you'll be fine. I've modified a few things over the years, i often go back to something similar to stock. It's easier. And now that you have 2 engines, you can have one set up with the pressure feed bearings, and any spare change/parts can build the other one as a "basic stock" engine as a spare (sounds like the one that broke at the lights is a good candidate for this)
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
10-29-2019, 11:33 PM | #15 |
I build my own engines for FAR less than what the workshops cost. For long distance (longest single trip I've done is 15,000 miles while towing), I go all the way for a little more get up and toughness. Whatever you do, don't drill the original Model A crank shaft for oiling the mains. You'll almost certainly have it break on you. Here's what I do
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 12-03-2019 at 04:38 AM. |
10-30-2019, 05:33 PM | #16 |
Why do you need a High Compression Head to do 50 MPH ?? It that case I should have blown my 1928 Coupe Engine a long time ago, including driving it from San Diego to Rhode Island in 1965 with a Original Engine with 68,000+ miles on it at speeds in the Desert up to 60..
10-30-2019, 10:25 PM | #17 | |
You can do 60 on a stock engine, but it is not helping anything in there. If you want to drive fast, build a touring engine.
12-02-2019, 10:46 PM | #18 |
Thank you all for the helpful information! Does anyone have experience with Lilleker Antique Auto in College Station? The price is very good and I could get the engine to them pretty easy, but I’ll pay more if needed to get a reliable engine.
https://www.mrmodelt.com/complete-mo...ngine-rebuild/ Not looking for high performance, stock is fine. 60mph is too fast for the rest of the car in my opinion. Just want a reliable engine that I won’t have to remove again. |
12-03-2019, 12:45 AM | #19 |
One more vote for Ron Kelly.
You will never look back with his work. Get re done.... and those pretty little ladies back in the A! Gil. NoCal |
12-03-2019, 01:07 AM | #20 |
When you are considering a rebuilder be sure to check them out in the archives. Go to the black bar at the top of the page and click "search". Remember that even the best shop will goof sometimes, the important thing is how they handle it afterwards. Look for patterns in comments that people post.
Charlie Stephens |
