02-18-2022, 05:51 PM | #1 |
Radial Tires
What size radial tires can you safely run on 4 x 16 Ford rims?
02-18-2022, 06:04 PM | #2 |
Re: Radial Tires
Message retracted.
02-18-2022, 09:08 PM | #3 |
Re: Radial Tires
I run 215 85r 16 radials. They are tall and skinny like a stock tire. Because I'm a cheapskate I buy them secondhand as they are standard issue on most dually pickups. I took delivery of two more yesterday for the rear of my '47 half ton, well it's a woodie wagon now. No tubes needed, they stay inflated nicely even on my heavily rutted, 1/2 mile of steep gravel road.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-19-2022, 04:28 AM | #4 |
Re: Radial Tires
Here's one on my old 1933 with 16" 1935 spokes-mounted tubeless.Its a 215X75 X16New owner of the car has had no issues whatsoever.
02-19-2022, 11:44 AM | #5 |
Re: Radial Tires
02-20-2022, 10:03 AM | #6 |
Re: Radial Tires
02-20-2022, 10:33 AM | #7 |
Re: Radial Tires
I installed Diamond Back 6.00 R 16 no tubes on my 38 wide fives - 40 lbs pressure. Make sure the rims are clean and sealed.
02-20-2022, 10:45 AM | #8 |
Re: Radial Tires
I did a pair of 16 inch 35 wires with 500-16 Excelsior radials and a pair of 32 wires widened 2 inches with 700-18 Excelsior radials for a 32 Lakester I started and Dale has several thousand high speed miles on them with no problems
02-21-2022, 08:24 AM | #9 | |
Re: Radial Tires
COMMERCIAL T/A ALL-SEASON 2 - SIZE: LT215/85R16 The big draw back they are heavy 36 lbs each. I only have them for the big little look. I have 195-85-16 on front which are about the the same as 700-16 but that size is discontinued. I use this for reference https://www.tirerack.com/tires/sizes...sp?diameter=16 |
Thread Tools | |
Display Modes | |
