05-24-2021, 11:43 PM | #21 | |
Re: Rough idle, low vacuum reading ?
Certainly so. Why having lower compression when running a supercharger is a thing. Also why you increase valve spring tension. I understand that duration could be problematic. But why run that cam? and does it lower engine vacuum? There was a suggestion that it is normal for some cams to have lower vacuum readings and run well. Last edited by Tinker; 05-25-2021 at 12:02 AM. |
05-25-2021, 08:54 AM | #22 |
Hi Tinker I remember adjusting the carburetor just as you posted but also listening for the highest sound of it sucking air. That was in the 50s. Yes Longer Duration does lower vacuum.
05-25-2021, 08:57 AM | #23 |
With the larger overlap with most aftermarket cams, idle quality is not as good because of dilution of the air/fuel charge. That's why more advance is beneficial.
05-26-2021, 07:46 AM | #24 |
Sorry I neglected to say, I do have an L100 cam. I only mentioned my readings because the original poster is running the L100 as he mentioned in post #11. I'll add that it runs a steady 17 vac at 50-60 mph.
05-26-2021, 06:44 PM | #25 |
Thank you all. Lot of good info there.
Seems like 550 RPM and 13-14 inches of vacuum is kinda low on both counts, is that a stock cam, and is 13-14 inches of vacuum normal ? Woops, Sorry I missed the 2nd post about the L100 cam in the 8BA I was wondering if the crab distributor may have some limitations in my application. |
05-26-2021, 07:21 PM | #26 |
05-26-2021, 11:21 PM | #27 |
So I'm going to ask a stupid question. What is the advantage to overlapping duration? Certainly air/gasses must be released with more air introduced.
