09-26-2014, 06:16 PM | #21 |
Re: UPDATE - Horn Rod/Light Switch Fiasco!
Yes I have. The rod as everyone mentioned is thicker than the older ones. So the only place that it actually contacts is at the top where the bushing is once it's all the way in the column.
09-26-2014, 06:26 PM | #22 | |
once it drops in with no friction youll be good use some grease up top also |
09-26-2014, 06:27 PM | #23 | |
once it drops in with no friction and spins relatively free you'll be good use some grease up top also |
09-26-2014, 06:36 PM | #24 |
I believe no one has mentioned what keeps the rod from moving. The light switch has a plate in it with three brass bumps. The bumps fit into brass depressions on the Bakelite (plastic) disk that is at the end of the wiring harness. I have seen reproduction parts where the bumps are not big enough and/or the depressions are not deep enough. If these two parts are not matched up there will not be enough resistance on the rod and it will turn with the steering wheel. I was able to fix one by building up the bumps with solder.
Bob Last edited by Bob Johnson; 09-26-2014 at 06:37 PM. Reason: spelling |
09-26-2014, 06:41 PM | #25 |
do you have a caliper that will allow you to measure the bushing diameter and the diameter of the rod? surely there are guys here that can tell you what kind of clearance is necessary
09-26-2014, 06:41 PM | #26 |
09-26-2014, 06:58 PM | #27 |
09-26-2014, 06:59 PM | #28 |
I do not have a caliper and am not familiar with them or where to get one, but if it'll fix the problem I'll go buy one!
09-26-2014, 07:00 PM | #29 | |
Thanks. How much solder did you use? I've seen the top end of the switch and know the bumps you're talking about. |
09-26-2014, 07:06 PM | #30 |
Sconnors, Watched your video did not see spring and brass centralizer that goes between horn button and steering wheel. centralizer not bushing for rod.
Thanks Dana |
09-26-2014, 07:12 PM | #31 | |
Bob |
09-26-2014, 07:16 PM | #32 | |
In my video I had left the bushing totally out. There was no spring between the horn button and the steering wheel. There is a spring inside the horn button. |
09-26-2014, 07:20 PM | #33 | |
Thanks, as far as I know there is no separate spring in the top part of the housing. There is a spring under the horn button but that is encased in the switch. The switch sets down inside the steering wheel against the brass bushing. Unless I'm missing something. |
09-26-2014, 08:26 PM | #34 |
I went back through all your postings....did you rebuild that steering gear in any way? is the steering wheel original or repro?
09-26-2014, 08:28 PM | #35 |
Here is a picture of the spring I referred to. Laso notice the height of the brass bumps.
Bob |
09-26-2014, 08:41 PM | #36 |
09-26-2014, 08:43 PM | #37 |
09-27-2014, 10:35 AM | #38 |
Taking today off from working on the truck. Tomorrow I will be back at it and am going to do the following:
With the spider, spring and clip out when you turn the steering wheel should the light switch turn with it? Someone posted yesterday that it will and that the spider, spring and clip prevent it from turning. My goal is to take the column out only once. The last time I slid the sector shaft through the frame to hold it in place, bolted the steering column to the bracket support in the cab and spun the wheel to test if the switch was moving but I DID NOT have the spider, spring and clip attached. Just wondering if it makes a difference. If anyone has any other suggestions that the ones I've listed PLEASE send them my way. Back at it tomorrow. As a guy we all know and respect once said: “Whether you think you can, or you think you can't--you're right.” Henry Ford |
09-27-2014, 11:20 AM | #39 | |
with the steering shaft. Bob |
09-27-2014, 03:15 PM | #40 |
That is the heart of your problem. Now you also have to space the horn rod from the retaining nut under it in the steering wheel since I see the surface of the nut was agressively ground down and is not level. If you loose your cool, drink a beer, relax and give yourself a break. Don't let a little learning frustrate you to the point that this is no longer recreation. life is too short. Worse case is you have to replace the steering shaft. I have a steering column that failed as I was backing the car into the storage. the top of the shaft is weak where the capture nut threads end.
Lights are less dangerous than no steering. Bob |
