Old 06-22-2021, 05:29 PM   #1
fsacht
Default Wiring insulation burn-through
I, after many years with 40's flatheads learned that wires; sparkplug, temp sender crossover, etc. that rest on the intake manifold can and do burn through in the area of the carb. Any of you experience this and do you know a source for conduit that is fabric or other not shiny material to cover those wires where they burn through?
fsacht is offline   Reply With Quote
Old 06-22-2021, 05:49 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Wiring insulation burn-through
Look here:
https://www.google.com/search?q=heat...hrome&ie=UTF-8
Old 06-22-2021, 05:55 PM   #3
Terry,OH
Terry,OH's Avatar
Suggest you replace with high temperature wire (Like used in stoves) You can get it in black with the cloth like outer cover.
Old 06-23-2021, 10:46 AM   #4
JayChicago
JayChicago's Avatar
I believe all our usual vendors sell cloth covering to make up wire looms. It's intended to look like original cloth covering. I would think your cloth covered wires would be protected if in a second cloth loom, and the appearance would be near-correct.
Old 06-23-2021, 11:02 AM   #5
Clem Clement
Clem Clement's Avatar
Contact Tyre Harris
Old 06-24-2021, 04:26 PM   #6
fsacht
Thank you all for your input and suggestions.
