Old 04-10-2021, 01:11 PM   #1
LouMercado
Default Help!!!
I have a 1930 model A. I was starting perfectly .... it would crank and start immediately. All of a sudden it cranks forever and I can’t get it started. What happened ? The battery is charged.
Any ideas ?
LouMercado is offline   Reply With Quote
Old 04-10-2021, 01:19 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Help!!!
Blocked fuel line and blown/missing fuse are some common causes.
Old 04-10-2021, 01:32 PM   #3
LouMercado
Default Re: Help!!!
Thanks I’ll check that
Old 04-10-2021, 01:45 PM   #4
31Tudor
31Tudor's Avatar
Default Re: Help!!!
Yes check fuel, and perhaps the points need to be cleaned up, especially if it has been sitting for a while. Check to see if you have power to the junction box, both terminals; power to the coil , with the switch on -power to the points (the points need to be open, or put something insulating between them) spark out of the distributor, plugs sparking. Carburetor clean and nothing blocking fuel flow. Need to rule out spark and fuel. engine needs spark, fuel, and air.
31Tudor is offline   Reply With Quote
Old 04-10-2021, 02:00 PM   #5
Jacksonlll
Jacksonlll's Avatar
Default Re: Help!!!
Try your horn. If it works, your fuse is good. Easy.
Pass a business card between the points to clean them. If it ran last month, don’t start changing anything. Find the problem and fix that. Good luck.
Old 04-10-2021, 02:50 PM   #6
McMimmcs
McMimmcs's Avatar
Default Re: Help!!!
Pay attention to this guy, he only gives great advice.
Old 04-10-2021, 02:56 PM   #7
jg61hawk
Default Re: Help!!!
It was running when you shut it off, so it is either spark or fuel. Quick and easy check with some help shoot a little starting fluid into carb as the engine is being cranked, if it fires at all then you have a fuel problem. If it does not fire then you have spark problem. Take a plug out and ground the plug to the engine block and have someone turn the engine over with the starter does the plug spark (other methods are acceptable too such as a screwdriver grounded to engine and held close to spark plug wire...look for spark. If no spark see the below:
Here is a copy of a post Mike V posted. Please read the entire post.....If it is the junction box ...should be power on both sides. If not the Amp gauge is bad. Jump across the two lugs of the junction box to bypass meter....
Default Re: Coil problem?
Mike V Florida has posted this and I think it's wonderful:
This is my generic no spark troubleshooting list,
No Spark
Some possibilities are:
1.Blown or defective fuse (use of a fuse is an aftermarket item)
2.Bad connections at ammeter, or ammeter itself (t0 find out put a jumper wire from one post of the terminal box to the other to take the ammeter out of the circuit temporarily)
3.Bad ignition switch and/or cable, or loose cable connection at the switch.
4.Loose or broken wires at bottom of coil
5.Loose or broken wires inside terminal box
6.Loose, bare or broken pigtail wire under distributor plate, or wire grounding to plate or distributor body
7.Points not opening, or point arm grounding to cam due to worn rubbing block
8.Worn electrode in underside of distributor cap
9.Loose or broken high tension wire from coil to cap
10.Condenser burned out or grounding (some condensers are too long and can touch the distributor body inside)
11.Weak coil
12.Rotor not turning due to loose cam screw or bad timing gear.
Ok now break out a volt meter (a light bulb can give false readings).
Start at the fuse block, you should have voltage on both sides of the fuse. If you only have voltage on one side, replace the fuse or fuse block.
Now with voltage on both sides of the fuse, move up to the junction box. There should be voltage at both terminals. If voltage is present only on one side the problem is at the ampmeter and you should Jumper the ampmeter for now.
You should have voltage on both sides of the coil. If not,
remove the red wire on the coil and check again. If you now have voltage on both sides, you have a problem further on. If the voltage is still only in one side you have a bad coil.
Open the points with a piece of paper and remove the condenser. Turn the key on and you should have voltage at the points.
Replace the condenser and you should still have voltage.
If the voltage is missing, remove the top plate and check for voltage on the bottom plate.
Check if the connector from the ignition switch screwed in too far? Do you have voltage on the wire to the upper plate?
Is this wire shorting to ground or broken?
Remove the paper from the points and see that the points are closed. You should not have 0 volts at the points. If you do, the points are dirty or the distributor is not grounded well to the engine.
jg61hawk is offline   Reply With Quote
Old 04-10-2021, 02:59 PM   #8
jg61hawk
Default Re: Help!!!
Keep us updated...I can't stand typing my fingers off and never hearing if anything worked.
Old 04-10-2021, 03:02 PM   #9
LouMercado
Default Re: Help!!!
Any ideas ?
Thank you everybody. I’ll take your recommendations next weekend
Old 04-12-2021, 04:20 AM   #10
shew01
shew01's Avatar
Default Help!!!
I’ve had starting issues similar to this twice. The first time it was a bad ammeter, and connecting a jumper across the junction box studs helped me find it.
The second time, it was a bad tachometer, which was attached to both coil studs. The tachometer was robbing the coil of energy, which caused the coil to deliver poor spark. Disconnecting the tachometer helped me find it.
Old 04-18-2021, 10:27 AM   #11
jg61hawk
Default Re: Help!!!
well?
Old 04-18-2021, 05:15 PM   #12
chl
chl's Avatar
Default Re: Help!!!
check if your points have closed up.
chl is offline   Reply With Quote
Old 04-18-2021, 05:22 PM   #13
GeneBob
Default Re: Help!!!
I once had a choke linkage disconnect from the choke rod and shut the car off like you turned off the ignition. I was trouble shooting something else when I bumped the choke link on the carb and found it was disconnected. Otherwise, I was probably going to get towed home. Just another unexpected place to check.
GeneBob is offline   Reply With Quote
Old 04-24-2021, 12:27 PM   #14
jg61hawk
Default Re: Help!!!
Hey Lou any luck?
Old 04-24-2021, 01:18 PM   #15
Ray in La Mesa
Default Re: Help!!!
GeneBob, Had the same thing happen, choke arm came off the shaft, was heading to a funeral late. Took a clothes pin off my gas line (I just store some there for emergencies like this, it doesn't vapor lock) and clipped it to the choke shaft, weight of clothes pin kept the choke open till I got home.
Ray in La Mesa is offline   Reply With Quote
Old 04-25-2021, 11:58 PM   #16
California Travieso
Send a message via Yahoo to California Travieso
Default Re: Help!!!
No Spark
11.Weak coil
well?
I think he’s been working on your post for the last 15 days. 😇
David Serrano
California Travieso is online now   Reply With Quote
Old 04-26-2021, 01:50 PM   #17
jg61hawk
Default Re: Help!!!
I think he’s been working on your post for the last 15 days. ��
Ha that's good. He must be up to the last two paragraphs by now!!!
Old 04-27-2021, 06:13 PM   #18
jerrytocci
Default Re: Help!!!
Could be timing gear.
jerrytocci is offline   Reply With Quote
Old 06-03-2021, 12:56 AM   #19
jg61hawk
Default Re: Help!!!
Correction to my post....
I think there is a mistake a typo...I believe the following is correct
With the points open (paper inserted) there should be battery voltage at all times. With the points closed ( no paper) there should be 0 volts at all times. [ key on].
The posted "you should not have 0" ...I believe should read "you should have 0" .
https://www.fordbarn.com/forum/showt...olts+key+on%5D
Read # 6 and then 7 of the attached thread.... Points closed 0 volts would be correct.
