Old 11-19-2018, 11:50 AM   #1
Larryejoh
Larryejoh's Avatar
Default Tire cover with mirrors
I'm planning on getting spare tire covers for our roadster. Does anyone have a picture of sidemounts with tire covers and a strap on mirror? The strap will partly cover the Ford logo so I'm thinking of getting covers with no logos.
Larryejoh is offline   Reply With Quote
Old 11-19-2018, 12:03 PM   #2
oldforder
oldforder's Avatar
Default Re: Tire cover with mirrors
I have heard that they look nice, but are basically useless as mirrors due to the vibration.
oldforder is offline   Reply With Quote
Old 11-19-2018, 03:24 PM   #3
Larryejoh
Larryejoh's Avatar
Yes they do vibrate. I already have them on the car. I didn't know how they would look with the Ford logo tire covers.
Old 11-19-2018, 03:42 PM   #4
Dutie
Dutie's Avatar
Here ya go Larry.
Dutie is offline   Reply With Quote
Old 11-19-2018, 03:55 PM   #5
Larryejoh
Larryejoh's Avatar
Thanks. Mine has the leather strap instead of the chain but I guess that will work.
Old 11-19-2018, 05:25 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Exactly right, plus the distance from the driver's eyes makes the field of view very small.
Consider them useless bling.
Old 11-19-2018, 06:11 PM   #7
1931 flamingo
1931 flamingo's Avatar
I have the mirror on my left sidemount, can't see ANYTHING ! ! FWIW
Paul in CT
Old 11-21-2018, 07:24 AM   #8
Dave in MN
Dave in MN's Avatar
Tom, You have a good point about the small field of view but they do help. I have one on the driver's side and use it to check the blind spot when the top is up. Yes, there is a good sized blind spot when the top is up...even more if you travel with the rear and middle side curtains installed as we often do.
I forgot to put it back on, after rotating tires, before leaving on our east coast road trip last fall. I had a few close calls that would have likely been avoided had I had the mirror installed. Maybe it's that I have become used to having it available that makes it necessary for me.
To help eliminate the vibration and blurred reflection, I fold a small cloth shop towel to the size of the base on the mirror and then place the towel between the tire and the mirror base. Tightening the leather strap with the towel between eliminates most of the vibration. Without the towel: Yes, it vibrates to the point of not being very useful.
Good Day!
Dave in MN is offline   Reply With Quote
Old 11-21-2018, 10:30 AM   #9
daveymc29
daveymc29's Avatar
I don't use fender mirrors presently. Found them blurry at best. Might try it with the towel. I use mirrors on the side windwings. I attached convex mirror over the flat glass, helps me a lot. Also the door window on my coupe without wind wind wings is convex. Might give it a go if not a show car.
daveymc29 is offline   Reply With Quote
Old 11-21-2018, 04:50 PM   #10
Dutie
Dutie's Avatar
Tom and Flamingo are right on, useless. These cars are a lot of shake rattle and roll. The only mirror of any use are on the stanchions. HAPPY THANKSGIVING TOO ALL. Dutie
