11-15-2017, 10:21 PM | #1 |
Grinding horn
I just picked up a Tudor, and one of the first things I want to fix is the horn. It sounds like a bunch of screws grinding in a coffee can. Where do I start? Just open it up and see what appears to be broken/worn? I see you can buy everything in the horn new, I'm just not sure what to start with.
As a related question, Some wiring is missing to lights, etc., where can one purchase the correct original wiring? I assume it was cloth insulated? Can anyone possibly point me to pictures of a restoration with routing of original wiring to lights, etc? |
11-15-2017, 10:45 PM | #2 |
Re: Grinding horn
Before you start to dig into your car get some literature and an owners manual. Most repair and owners stuff is reproduced and reasonably priced. Bert's, Bratton's, Snyder's and many others have what you need in wiring and whatever else you will end up needing. Have fun with your car!
11-15-2017, 11:16 PM | #3 |
Re: Grinding horn
On the horn , start with a little oil and adjustment . Then go from there .
11-16-2017, 02:32 AM | #4 |
Re: Grinding horn
Here is a easy horn tune up
http://modelabasics.com/horn.htm
11-16-2017, 11:16 AM | #5 |
Re: Grinding horn
SteveR: welcome to the barn. Congrats on the Tudor. Fantastic choice. As figment stated, start with a little oil and adjustment. New wiring harnesses can be purchased from the vendors. Good Luck. Where do you live? You may have barners in your back yard that you didn't know about. All the best. Jeff
Let's let pylons, be pylons! |
11-16-2017, 12:03 PM | #6 |
Re: Grinding horn
11-16-2017, 08:20 PM | #7 |
Re: Grinding horn
Take it apart and see what the problem is.
11-18-2017, 05:17 PM | #8 |
Re: Grinding horn
You might try electric parts cleaner in a spray can. I just tried it on both my cars and the horns never sounded so good!
Dick |
