Old 07-06-2016, 08:56 PM   #1
LPTIMOS
Default Removing door glass from 1933 Ford Pickup
How do you remove door glass and channel out of 1933 Ford pickup door?
Thanks, Larry
LPTIMOS is offline   Reply With Quote
Old 07-06-2016, 09:40 PM   #2
Straightpipes
Straightpipes's Avatar
Default Re: Removing door glass from 1933 Ford Pickup
It comes straight out the top after you remove the door top panel.
Straightpipes is offline   Reply With Quote
Old 07-07-2016, 09:15 AM   #3
LPTIMOS
How do I remove steel channel from the window regulator? Do I remove the window regulator from the door? 734-645-1099
Thanks, Larry
Old 07-07-2016, 09:49 AM   #4
Krylon32
Crank it up to where the end hole in the channel lines up with the end of the regulator arm and pop it out
Krylon32 is offline   Reply With Quote
Old 08-12-2016, 06:15 PM   #5
LPTIMOS
Krylon, The travel stops before I hit the end of the travel. What am I doing wrong?
Thanks, for your help.
Larry
Old 08-12-2016, 07:23 PM   #6
Flowmeister
Flowmeister's Avatar
Undo the three regulator screws, slide it to the big hole end of the glass channel, pop it through, remove it through the big triangle hole in door. slide glass up and out of door top.
Flowmeister is offline   Reply With Quote
Old 08-13-2016, 06:21 PM   #7
LPTIMOS
Flowmeister, Thanks the window is out. I do have another question. How do install the window channel, do you install bottom tab and then bend the top one over?
Thanks, Larry
