02-14-2016, 05:49 PM | #1 |
39 coupe gearlever gaiter and mat .
hello ,just a quick one ...I put on a new gaiter ,I put it under the metal gearbox cover added the floorboards and it looks ok , a new rubber mat arrived and the hole cut in it is small ,do I put the gaiter over the mat or under the mat but over the metal cover or the way I,v done it under the metal cover ?a dumb question to some but if you don't know you don't know , thanks Jim.
02-14-2016, 06:15 PM | #2 |
Re: 39 coupe gearlever gaiter and mat .
What's a gaiter?
02-14-2016, 06:27 PM | #3 |
Anything akin to a garter??
02-14-2016, 06:43 PM | #4 |
I'm not familiar with the word "gaiter" either. So, off to Google and here's what they say.....
Gaiters are garments worn over the shoe and lower pants leg, and used primarily as personal protective equipment; similar garments used primarily for display are spats. Originally, gaiters were made of leather. Today, gaiters for walking are commonly made of plasticized synthetic cloth such as polyester. Gaiters for use on horseback continue to be made of leather. Would this possibly be a leather or rubber boot that goes over the top part of the shift lever tower?
02-14-2016, 07:03 PM | #5 |
sorry ,I guess a gaiter is an englishism , its the rubber boot that goes over the gear lever ...........lets start over again .
02-14-2016, 07:36 PM | #6 |
02-14-2016, 08:50 PM | #7 |
Are they standard?
It is my understanding that they were add on, and not factory. |
02-14-2016, 09:18 PM | #8 |
39 Mercury used a boot over the gear shift, Fords did not use one. I would say, if you are going to use one, it should go on top of the metal floor board, but under the mat, with only the upper part of the boot showing.
02-15-2016, 10:43 AM | #9 |
Thanks guys ,that,s another one sorted.
02-15-2016, 01:41 PM | #10 |
If you are speaking of the rubber boot that was intended for the Mercury car, I put one my 39 when I restored it about 8 years ago. After seeing other nice Dearborn 38 and 39 Fords at shows, I removed that boot from my 39 Convertible. We just finished restoring a 39 Deluxe coupe and I used a Carpenters floor mat and the gearshift tower fits tightly in the hole in the mat. Just my opinion, the 39 looks much better without the loose fitting boot. The boot does not fit properly over the rubber mat nor under the mat. This is the way that the 39 Ford came from the factory, without the boot. This from my own trial and error. Good luck with your Ford. Tom Byrd
02-16-2016, 02:10 PM | #11 | |
02-16-2016, 11:30 PM | #12 |
We need to help each other in this hobby,I took this 39 convertible apart in 1965 and started restoring it around 1998, I had to do a lot of research and checking other 39 convertibles in order to put that puzzle back together!
